T-Case output shaft help - Defender Source
Old August 6th, 2004, 09:38 AM
WhiteD90's Avatar
WhiteD90
Johnathan Tisdale
93 110, 90 RockRR buggy
Anyone know what size socket is used on the output flange nut(big one recessed in the parking brake drum) and what the torque spec is for it? Thanks!
Tis
Old August 6th, 2004, 10:13 AM
I think its 30 mm and 120 ftlbs of tork, ask Yousef he just did his.
output shaft spline wear ZACHASS Defender Technical Discussions 8 February 3rd, 2009 04:01 PM
LT-230 output shaft bearing number? PTSchram Defender Technical Discussions 1 September 27th, 2007 03:15 PM
Lt77 Output shaft replacement Hans Defender Technical Discussions 5 December 9th, 2005 04:33 PM
Transfer case output nut size? Trigger Defender Technical Discussions 5 April 12th, 2005 03:32 PM
Auto trans output shaft extension needed JCRover4x4 Wanted 1 June 15th, 2004 10:10 PM
