T-Case output flange question - Defender Source
Old March 19th, 2013, 12:49 PM
gonzanc's Avatar
gonzanc
Nick
'95 4.2L NAS D90
I just finished installing the front and rear transfer case flanges on my 1987 D-90 and both seals and flanges went on without a hitch. However, in the front, after installing, it is now very difficult to spin the flange. Prior to installing, the flange would freely rotate with very minimal effort, now, I have to use the butt end of a hammer to rotate the flange. Is this normal? Should I be concerned?
The rear is a little more tight than the old flange, but I can still rotate it with my hand (driveshafts are removed, btw).
Please let me know as I do not want to drive it if it is something that could potentially be wrong.
Thanks!
Old March 21st, 2013, 09:15 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
It shouldn't be that hard to turn. All I can think of is maybe you got the seal really crooked, or not seated far enough. Assuming the TC is actually not locked.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old March 21st, 2013, 05:20 PM
gonzanc's Avatar
gonzanc
Nick
'95 4.2L NAS D90
The seal is straight and seated properly and the diff is not locked. I think is has to with the mud shield and how it sits on the Drive flange
Old March 21st, 2013, 05:23 PM
Is the mud shield on the flange properly? It should not touch anything. Is the seal countersunk fully? Did you use grease?
Old March 21st, 2013, 05:31 PM
gonzanc's Avatar
gonzanc
Nick
'95 4.2L NAS D90
Yes, yes, yes. It has gotten easier to spin, but I won't know until I take it for a drive. Just waiting on the new drive shaft...
Front output flange lynchee Defender Technical Discussions 6 September 10th, 2009 03:55 PM
Another heater output question GaryBaxter Defender Technical Discussions 19 January 15th, 2008 07:31 PM
LT230T Front Output Flange questions...... kiphartzell Defender Technical Discussions 20 March 2nd, 2006 08:17 AM
Lt77 Output shaft replacement Hans Defender Technical Discussions 5 December 9th, 2005 04:33 PM
Transfer case output nut size? Trigger Defender Technical Discussions 5 April 12th, 2005 03:32 PM
