T-case input shaft Bearing #s - Defender Source
Old June 3rd, 2005, 07:03 PM
Anyone know the bearing #s on the input shaft of the LT230? Thinking of changing them this weekend but I want to hae new bearings in hand first.
Thanks!
Old June 3rd, 2005, 09:05 PM
JohnC
Giampaulo Cinquegrana
95 DI SR Extreme Kit - 94 RRC LWB
Hope this helps. I don't know what the x-reference # is, sorry.
John C.
Old June 3rd, 2005, 09:17 PM
Hmm, searched it some and the only thing I find in referance to bearings is with that # is that page. it must be a Ashcroft number.
Old June 4th, 2005, 11:11 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Mike, thats a LR part # IF someone has a case apart, they can get the # off of the Timkin bearing
Legend in My Own Mind.
Old June 4th, 2005, 11:55 AM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
I only have output shaft #"S
Old June 4th, 2005, 01:48 PM
Well I pulled the input shaft out and the bearings and the race ways looked good, so I don't have to replace them, I think I would have had to pull the bearings off the input shaft to get the #, and since I don't have a press I left them on. They were covered some by the muck that made it's way into the T-case so I cleaned them all up and put them back in, hope it holds!
Old June 4th, 2005, 05:03 PM
LT85
PATRICK CORBETT
LT23 Input Shaft Bearings FRC5564
Just for the record the input shaft (Mainshaft Transfer Gear) bearings are FRC5564 Land Rover which cross refs to 18790/18720 Timken and a few other decent Jap Brands.
Old June 5th, 2005, 08:22 PM
Cool! Thanks Patrick! I just talked to Jimmy S and he has an extra set from the T-case swap we did on his 90.
Old June 6th, 2005, 05:37 AM
jimmy salmon's Avatar
jimmy salmon
jimmy salmon
94 D90 AA Yellow
Hey Mike i will overnight them to whipper's.They will be there tuesday
Old June 6th, 2005, 02:32 PM
jimmy salmon
jimmy salmon
94 D90 AA Yellow
Federal Mogul # 4T-18790
Old June 8th, 2005, 06:52 PM
LT85
PATRICK CORBETT
Yeah that ties up. 18790 is the cone 18720 is the cup, 4T is an NTN prefix so that Federal would be an NTN bearing.
Patrick.
Transfer box input bearing preload reb78 Defender Technical Discussions 10 October 29th, 2008 05:04 PM
LT-230 output shaft bearing number? PTSchram Defender Technical Discussions 1 September 27th, 2007 03:15 PM
R380 Transmission Input Shaft Bearing Question Heath Defender Technical Discussions 0 March 15th, 2007 03:09 PM
LT230 questions and concerns - bearing failure. kiphartzell Defender Technical Discussions 4 January 13th, 2006 01:56 PM
Lt77 Output shaft replacement Hans Defender Technical Discussions 5 December 9th, 2005 04:33 PM
» Defender Registry
Fezzik
Factoid
Honcho
bennett
Add your Defender
