t-case input gear question.... - Defender Source
Old January 22nd, 2010, 05:47 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
I have a brand new t-case input gear but it is the older one that is not cross drilled. Can I have it drilled by the local machine shop? WHat size hole is it and where is it located?
Legend in My Own Mind.
Old January 22nd, 2010, 06:03 PM
I was going to offer to snap a photo of my spare one, then I remembered that it is sealed up inside the case again.
I would suggest looking at the ashcroft site, they have some good pics of them.
you can also fit the oil thrower instead that is the cheap/easy way out and seems to work just fine. Basing that on the fact that the case I just fitted to my truck had one and the splines were perfect. there was a ton of oil back there when I pulled the cover off the first time, and since i forgot to reseal the pto cover before installing the case, the thing was puking out oil at a rather unbelievable rate. (since fixed)
Old January 22nd, 2010, 07:56 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
does anyone sell the thrower? I would do that but if I can drill the gear, I will do that too... Easy enough if Its possible.
Old January 22nd, 2010, 08:02 PM
Chaucer
Will
93 110 | 97 90
You might be able to guess the size of the hole and see the location by looking at the picture on Ashcroft's website: http://ashcrofttransmissions.co.uk/part_28.html
Old January 22nd, 2010, 08:21 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
interesting... so does the gear have 4 holes all together in it??? or just the 2 in the picture?
Old January 22nd, 2010, 08:29 PM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
4 holes. (2 all the way through). The gear is hardened so you need to grind a flat spot to get past that and then you can drill it yourself with a drill press.
Matt Browne
Old January 22nd, 2010, 08:36 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
I am guessing Rob Dassler would be your best bet for a thrower if you decide to go that route.
Old January 22nd, 2010, 09:53 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Thanks Matt... do you know what size?
Old January 22nd, 2010, 10:41 PM
Id like to hear more about this "oil thrower" I have a very late build 95 but I have never pulled the input gear to check. Is this oil thrower something simple? It seems like the redesigned input came on late 97 LT-230's
Old January 22nd, 2010, 10:42 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
I have a couple of the oiling plates sitting around if you need one. Good luck drilling the gear...I tried it once and only succeeded in ruining a couple of drillbits. I believe that the gears are hardened after machining....so even if you grind a nice spot to start drilling, you still have to drill through a hardened set of splines on the inside.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old January 23rd, 2010, 04:14 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
/Apparently/ the oil throwers bring up another problem... they lubricate the main shaft, yes, but stop oil from getting to the bearing at the end of the inspection plate.
Old January 23rd, 2010, 06:57 AM
Bill B
Bill
73 S3 109 Tdi, 95 RRC
I just went through this on my 109 LT77 LT230 conversion. Steve Parker have a thrower on their site and Ashcroft say they have them. Called Ashcroft and they said they no longer have any. However they had a rummage around and found one for about 15 quid. It was used. Jim is right, there are tales of the lack of oil to the end bearing. Some people suggest slightly overfilling the case. I guess only time will tell. The LR thrower I got from Ashcroft had two cut outs in it for the oil to get past the plate but can't say how much. Got great service from Ashcroft by the way.
Good luck
Bill B
Old January 23rd, 2010, 07:05 AM
junkyddog11
oil soaked filter
95 RRC 300tdi
I've only ever drilled one gear....for my own heap. At the time I didn't consider the hardening as an issue and only ground the flat spot for a good spot to start the drill. I did 4 holes from the outside and I don't recall having a big issue getting through the splines. Then again that was 10+ yrs ago and at this point things I did last week are somewhat fuzzy.
I buy new gears now. Not a big fan of the oiling plate. Seems like a bandaid.
Matt Browne
Old January 29th, 2010, 04:46 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
I will have the machine shop do it.. What size hole?
Old January 29th, 2010, 09:57 PM
junkyddog11
oil soaked filter
95 RRC 300tdi
err.....not sure without looking at one. I dont think it needs to be very big. 5/16?
Matt Browne
Old February 1st, 2010, 12:53 PM
LFORGUE8
Lucas Forgue
2011 Rangie
the one ive got on my bench has 25/64 holes.....ive never even heard of this thrower? anybody have a pic of it........i had bought this gear from ebay and i took forever to come in and i ended up installing my tcase with out it and did over fill the tcase with about 1/2 more quart and havent had a problem....ive got this one for a "spare"
59 SII....on the back burner!
11 Rangie
Old February 2nd, 2010, 09:32 AM
LRover's Avatar
LRover
J. Michael McCaig
The gear is very hard but you can drill it in a standard drill press set up with a vise and the right drill bit. I've done a couple and I used a 1/4" diamond tipped drill bit which gives you just a little smaller hole than factory. When you come out thru the inner splines there is a chance you will break the bit so have a spare. I followed the same pattern as the factory drilled gear otherwise.
Old February 2nd, 2010, 09:56 AM
photo of the gear
http://www.ashcroft-transmissions.co...rt_28.html#pa1
some nice photos and write-up of gearboxes including cut-away views. scroll down for pics and description of the oil feed plate
http://www.geoffrey-miller.demon.co....sfer/index.htm
Tips on Swapping out the T-Case input Gear? LRNAD90 Defender Technical Discussions 2 April 23rd, 2009 05:14 PM
output shaft spline wear ZACHASS Defender Technical Discussions 8 February 3rd, 2009 04:01 PM
LT230 Input gear again! Mike Hippert Defender Technical Discussions 17 June 19th, 2005 06:45 PM
Lt230rc redrover Misc. Chit-Chat 3 February 29th, 2004 09:09 PM
