T-case help - Defender Source
Old October 15th, 2011, 03:39 PM
jayz's Avatar
jayz
Jason Zolezzi
85 200tdi 110
T-case help
So, I installed my lift and everything seems to be going to hell. Went for a drive today and at a stop sign going up hill the diff just popped into neutral. I monkeyed around with it and got it back engaged but now as I am shifting when I engage the clutch to shift I get a clunk and when I let off the clutch I get a clunk again. When i get underneath the truck and turn the front shaft back and forth it is noisy(clunky) From the research I have done I am thinking the output bearing? Any other thoughts? Also the larger tires 265/75/16 seem to be sapping my upper end power, A hill I used to be able to take in 5th is now impossible without dropping into 4th. Is that normal for such a minimal increase in size?
Lift is 2". It is an LT77
Thanks for any help, Jason
Old October 15th, 2011, 03:57 PM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
What are the measurement on your lift?
Old October 15th, 2011, 04:50 PM
aka rover's Avatar
aka rover
ed angel
95 D90
There could be a bunch of things making a clunk , did you remove any of the arms on the suspension? Alot of driveline clunks can come from loose or worn bushings.
Try this for a cheap way to look and listen for clunks,
make sure you are on a safe level surface and put your tranny in first gear, then grab the rear tire while keeping clear of the pinch point under the tire" your feet", Now start rocking the truck back and forth listening for the clunk. Sometimes you have to rock pretty hard but you may get the clunk to show up and determine if its a suspension clunk or drivetrain.
Cheers Ed
Old October 15th, 2011, 05:43 PM
jayz's Avatar
jayz
Jason Zolezzi
85 200tdi 110
I didn't remove anything but the suspension when I did the lift. I am pretty sure it is coming from the transfer case because of the sound it made when hand turning the front drive shaft and the fact that it hapens when I engage and disengage the clutch while shifting
Old October 15th, 2011, 06:04 PM
aka rover's Avatar
aka rover
ed angel
95 D90
when you say suspension do you mean only coils and shocks?
Old October 15th, 2011, 07:45 PM
jayz's Avatar
jayz
Jason Zolezzi
85 200tdi 110
Yes, springs and shocks. The cranked front and rear arms are on the way with bushings and tie-rod ends
Old October 15th, 2011, 08:49 PM
how many miles on your truck? Have you replaced any of the bushing ball joints? 265/75 are stock size tires
Old October 15th, 2011, 09:01 PM
have you checked your drive flanges ? on 25yr old trucks they tend to be shot if they haven't already been replaced. play @ the wheel hubs may transmit back to the tcase since thats where the play is taken up every time you clutch and make a signifigant bang as the play is taken up. The rear axle a frame ball joint also make similar noise as the axle twists when the clutch is let out. Yes larger tires and lift exacerbate these issues.
On the tires size/power loss what does the decal on the back of your tcase say the ratio is ? 1.21 to 1 ?
Old October 15th, 2011, 10:43 PM
jayz's Avatar
jayz
Jason Zolezzi
85 200tdi 110
The odometer reads 95000 but who knows with an import. I will take a look at the drive flanges, I am sure they could use replacing along with everything else under this thing. I have new bushings coming along with castor corrected arms front and rear. I am not home but I will check the ratio when I get back. I appreciate all the advice
transfer case questions HELP! mattwhite Defender Technical Discussions 2 March 8th, 2009 02:45 PM
Transfer case output nut size? Trigger Defender Technical Discussions 5 April 12th, 2005 03:32 PM
94 transfer case problems Campbell Defender Technical Discussions 25 March 19th, 2005 12:09 PM
Rover Expedition Case w/ 4 walkie talkies jack frisch For Sale - Parts 0 February 27th, 2005 03:24 AM
transfer case redrover Defender Technical Discussions 9 January 27th, 2004 02:41 PM
