T-case flange measurement needed... - Defender Source
Old March 14th, 2016, 10:31 PM
Ash's Avatar
Ash
Ash Heller
OM606 110 Frankenstein
I forgot to grab one when I left the shop tonight. Does anyone have one that they can easily put a tape on? I'm looking for the measurement across the four bolt holes for the driveshaft. Thanks in advance!
-Ash
Geared Restoration Co.
352-572-3236
Old March 14th, 2016, 10:37 PM
The hole spacings are 2.0" and 2-3/8". The alignment bore is 2-3/8".
Old March 14th, 2016, 10:43 PM
Ash's Avatar
Ash
Ash Heller
Awesome. Thank you John.
-Ash
352-572-3236
Old March 14th, 2016, 11:11 PM
Ash's Avatar
Ash
Ash Heller
Ok, am I just tired or is there a typo in that diagram? Dim 'B' doesn't coincide up when I locate my holes using 'C1' and 'C2'. Granted, it's a very small amount and I guess I can just oversize my bolt holes slightly to play it safe. Where'd you pull that from?
-Ash
352-572-3236
Old March 14th, 2016, 11:22 PM
Baldewin's Avatar
Baldewin
Chris Baldewin
Bastard 90
Your right it doesn't work.
Old March 14th, 2016, 11:31 PM
The picture is from Tom Woods. Must be a typo. The diagonal is 3.105" as you show.
Old March 14th, 2016, 11:34 PM
Ash's Avatar
Ash
Ash Heller
Haha I just redrew it to illustrate the issue and you edited your comment. For posterity, here's what it looks like when I set the holes so that 'B' is correct per the diagram.
-Ash
352-572-3236
Old March 14th, 2016, 11:50 PM
Okay. Went and measured a flange.
2.0" and 2.395" and the diagonal does look 3.125" as best I could measure.
Old March 15th, 2016, 12:17 AM
Hard to find a definitive answer...
http://rockforddriveline.com/2_FlangeYokes_2014_10.pdf
Says 2.015, 2.390 and a diagonal of 3.125"
Interesting there is a Jeep flange yoke of the same dimensions. Maybe they used the original Jeep pattern?
Old March 15th, 2016, 07:06 AM
Probably intentional on Tom's part to discourage copycats
Old March 15th, 2016, 07:10 AM
All the flanges fit regular Dana Spicer pattern from early Series thru at least 1997
Old March 15th, 2016, 09:21 AM
Ash's Avatar
Ash
Ash Heller
I appreciate your help. Ended up using the above dims to draw my part, and I'll bounce them off a flange here before I send them to the laser. Thank you.
Yeah, that seems to be the most likely scenario.
-Ash
352-572-3236
Old March 15th, 2016, 08:29 PM
Had a bit of a look for a genuine Spicer flange yoke of the right size.
Northern Drivetrain, LLC: Spicer 2-2-459
Spicer 2-2-459
Bolt Circle Diameter B 3.125
Horizontal Distance Between Holes (center to center) 2.009
Vertical Distance Between Holes (center to center) 2.394
Bolt Hole Diameter .375-D
Bolt Hole Quantity 4.000
Pilot Diameter (M-Male, F-Female) C 2.375M
Accelerator Cable Measurement Needed rdavisinva Defender Technical Discussions 9 June 24th, 2015 10:15 PM
Defender SW measurement needed Macker Defender Technical Discussions 5 June 6th, 2013 07:29 PM
T-Case output flange question gonzanc Defender Technical Discussions 4 March 21st, 2013 05:31 PM
Nylock nut size, rear flange of transfer case - also identify T-case ratio hillstrubl Defender Technical Discussions 3 July 11th, 2012 02:42 PM
Measurement needed... J.5 Defender Technical Discussions 0 November 10th, 2007 06:22 PM
