T-Case Bearings - Defender Source
Old November 4th, 2008, 03:05 PM
outfield
Steve
1995 D-90 SW #351
T-Case Bearings
I have a slight amount of movement in the front and rear outputs of my LT230 T-Case. Most likely it's time for new bearings. Has anyone changed out just the input and output bearings? I can't afford a rebuilt T-case right now, but if it's feasable to install new bearings that is doable.
I searched the site and it seems that most rebuilds were after catostrophic failures... I'm hoping I can get away with minimal work.
Thanks for anyhelp you can prvide.
Old November 4th, 2008, 04:41 PM
Output you can do in situ, at least in front.
http://www.discoweb.org/tcasebearing/index.htm
Why do you think the input bearings are bad?
Also, it could just be that the nuts are loose giving the play.
Ron
Old November 4th, 2008, 07:14 PM
Montgo1715
D Montgomery
1994 AA
I just had the front output done in mine, fixed the play in the shaft but not the vibration problem I'm having. It vibrates between 30-37 MPH regardless of gear...weird. Its an inexpensive repair worth trying.
Now that is a big trunk. It holds a tuba, a suitcase, a dead dog, and a garment bag almost perfectly.
Old November 5th, 2008, 02:55 PM
outfield
Steve
1995 D-90 SW #351
Thanks guys!
I already printed the procedures to change the front bearing.
Ron, at the National Rally this year I started hearing a noise when slowing to a stop, it sorta sounds like a drill motor as it is slowing to a stop. I have this noise, and now at speed when coasting you can hear a rumble type noise, but while accelerating or when under compression, no noise. I pulled the rear 3rd member Saturday, all is tight there.
The rear output moves just slightly as does the front output. The rear output seal is bad and leaking oil into the e-brake drum too.
I need to suspend both axles and do some in gear tests in the garage, maybe this will help with the diagnostics.
I have a LR mechanic coming over this weekend for a second opinion, but knew I would get good feedback from here too...
Thanks again
Ron, I just realized I said input and output in the 1st post, I meant outputs.
Old November 5th, 2008, 03:18 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
Output bearings are 6207 ball bearings.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old November 5th, 2008, 03:24 PM
Outfield, you noise sounds like the diff in the case. If it was run low on oil (you said it leaked) that could have gone bad.
Roadsiderob is the true expert on these matters. I am just a hack who fixes LT230s on my table once in a while for fun.
Old November 5th, 2008, 09:17 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
After I go the old one [bearing] I took it to the bench grinder & ground down the outside a bit. Used it to set the new one.
transfer case questions HELP! mattwhite Defender Technical Discussions 2 March 8th, 2009 02:45 PM
Transfer case output nut size? Trigger Defender Technical Discussions 5 April 12th, 2005 03:32 PM
Rover Expedition Case w/ 4 walkie talkies jack frisch For Sale - Parts 0 February 27th, 2005 03:24 AM
Rebuilt LT230 Transfer case Bill Jansz For Sale - Parts 0 March 9th, 2004 07:00 AM
transfer case redrover Defender Technical Discussions 9 January 27th, 2004 02:41 PM
