T-case! - Defender Source
Old May 20th, 2004, 12:40 PM
TwisteD90's Avatar
TwisteD90
Yousef Hamzeh
06 RR SC, 06 LR3, 94 D90
T-case!
Is it possible to move the T-case up or down w/o unbolting the whole thing. I need to put the trailing arm bolt through the frame but the e-brake drum is in the way. Any idea?
Old May 20th, 2004, 12:58 PM
IF you loosen the bolts holding the T-case you may be able to move it a little, You may also want to try and remove the Drum as it looks in the pic your rear drive shaft is off so you only need to remove the screw that is holding the drum itself on.
Old May 20th, 2004, 02:45 PM
TwisteD90's Avatar
TwisteD90
Yousef Hamzeh
Yeah I might do that.
World traveler
Old May 20th, 2004, 05:14 PM
TwisteD90's Avatar
TwisteD90
Yousef Hamzeh
Thanks to Keith there is no need to touch the T-case.
World traveler
transfer case questions HELP! mattwhite Defender Technical Discussions 2 March 8th, 2009 02:45 PM
Transfer case output nut size? Trigger Defender Technical Discussions 5 April 12th, 2005 03:32 PM
94 transfer case problems Campbell Defender Technical Discussions 25 March 19th, 2005 12:09 PM
Rover Expedition Case w/ 4 walkie talkies jack frisch For Sale - Parts 0 February 27th, 2005 03:24 AM
transfer case redrover Defender Technical Discussions 9 January 27th, 2004 02:41 PM
