Synthetic winch rope - Defender Source
Old April 27th, 2008, 09:01 AM
Santiago
Santiago Gigola
Hello,
The Warn XD 9000i winch in my Defender has synthetic winch rope installed and since it was already there when I purchased the vehicle I do not know how old it is.
The rope has lost its colour (looks like it was some knind of reen or blue when new) and comes out flat and quite distorted when I pull it out. Although it has few very small "scratches" it looks lie it does not ave any serious failures. I have not used synthetic winch ropes before (I used wire instead) and therefore would like to know if it is normal that the ropes gets deformed and flattenede as mine does and if there are any other particular indications to diagnose if it is already time to change the rope or not. How long do they last if taken care properly?
I've measured the rope and it is about 1.2 mm in diametre whch sounds like a 7/16 rope, mor ethan enough for this winch if I am not wrong (5/16 wire comes standard with this winch).
I will post a picture later.
Thanks for our help!
Regards,
Santiago
Old April 27th, 2008, 09:21 AM
Santiago,
The synthetic rope is probably Amsteel Blue Brand. The rope will flatten out and disform when it has been used or wound and rewound on the spool. You should be able to fix this by unspooling the line, and respooling it back on, under pressure (i.e winching the truck to a tree) then you can control where and how the line goes back on.
As for the color, more than likely it has been sitting out in the sun. You could cover the winch and rope to protectit from further damage. Is it only the first few feet that are discolored?
Old April 27th, 2008, 11:19 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
There is a fool proof test to tell whether or not you should replace it. Use it, and if it snaps, replace it.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old April 27th, 2008, 06:57 PM
Santiago
Santiago Gigola
Hi guys,
Scott, it is discoloured all over, but much more towards the end. It looks like the original colour was light green(?).
I will add a couple of pics to illustrate better and see what you think (attached).
Thanks for your help.
Cheers,
Santiago
ID:	13100   Click image for larger version
Old April 27th, 2008, 07:15 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
That rope is fine, the fibers just get compressed together on a heavy pull. If you work it loose with your fingers it will seperate and round out again. It looks better than my 1 year old line.
Old April 27th, 2008, 10:20 PM
mdmccallum's Avatar
mdmccallum
'97 Defender 90 SW
Ditto. The line is fine.
Old April 29th, 2008, 06:19 PM
Santiago
Santiago Gigola
Thanks guys!
I'll jsut keep on usin it.
Regards,
Santiago
Old April 29th, 2008, 06:31 PM
whats a bad one look like?
Old April 29th, 2008, 08:56 PM
CDeWan
Clay DeWan
5.3L beastie
I guess you won't know what a bad one looks like until it snaps and then all sorts of descriptive words abound.
winch
Synthetic winch rope and roller fairleads? Santiago Defender Technical Discussions 3 August 3rd, 2009 11:17 AM
synthetic winch line good or bad ripp2002 Defender Technical Discussions 1 January 18th, 2005 07:28 PM
Dynaflex Synthetic Winch Lines Starting @ $280.00 RedRhinoProducts The Vendors Loft 1 November 4th, 2004 09:07 AM
Which synthetic rope revisited: snuffer Defender Technical Discussions 0 June 14th, 2004 07:59 PM
Which synthetic winch rope is... howellm70 Defender Technical Discussions 17 May 31st, 2004 01:57 PM
» Defender Registry
D90 y
Bjcraig
Meh-Teh
thewap
Add your Defender
