Synthetic winch line - 100' vs 125' - Defender Source
Old December 29th, 2012, 09:56 PM
Having trouble finding 3/8" in 125' from MasterPull/Amsteel Blue (their website now only rolls to their eBay store...not sure what is going on).
Anyhow I found the 3/8" in 100', but can't find any longer (was hoping for at least 125'). Any input on if this is really that big of a deal? Should I just pull the trigger on 100' and call it a day?
Old December 29th, 2012, 10:04 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
Get 100' and bring a 25' tow strap. You should always carry a tow strap.
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old December 29th, 2012, 10:07 PM
Yes you should always carry a tow strap in case a fellow bimabright brother needs a tow home!
Old December 29th, 2012, 10:09 PM
I've got a towstrap/etc, just like to minimize the additional shackle points / failure points...plus going synthetic to avoid any potential flying "obstacles".
Old December 29th, 2012, 10:12 PM
You would be better off with about 80 ft and an extension.
Old December 29th, 2012, 10:15 PM
Why is that?
Old December 29th, 2012, 10:16 PM
JackW's Avatar
JackW
Jack Walter
1966 109 SW Diesel
This guy can make up winch line in any length you need - and he's big supporter of many 4wd events across the southeast - good prices too.
http://www.southeastoverland.com/
Old December 29th, 2012, 10:23 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
X2. Steve is a good guy
Old December 29th, 2012, 10:30 PM
The winch has more pulling power the closer you get to the drum. And with 125 ft, you have to pull a lot of cable to get to the best pulling power. And, on the east coast, there is usually a tree close by.
Old December 29th, 2012, 11:07 PM
Ray_G's Avatar
Ray_G
Ray Gerber
Concur with Scott's point; if it's a choice between 100 and 125, just get the 100'-and if you're worried about long pulls get a winch extension (and keep the tow strap in the kit too).
Flexibility helps.
r-
Ray
Old December 29th, 2012, 11:11 PM
ukoffroad's Avatar
ukoffroad
Chuck Yarbrough
67 IIA
x3 on shorter, I have cut mine down to about 75ft. Doing pulls with 20-50 feet off of a 125ft rope is not the best. On the east coast you just do not need as much.
Chuck
67 Series IIA
The parts falling off this vehicle are of the finest British craftsmanship.
Old December 30th, 2012, 08:27 AM
Steve at southeast overland cut mine down to 65' and put a thimble on and made a 35'ish extension. I run the master pull 26k 3/8 x 100 on my SW husky 10. And I use one of the line locks, from dyna(something).
Old December 30th, 2012, 08:38 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
x4 on 100 or less, plus extensions. It makes spooling safer too IMO. Also probably why you're have a tough time getting it in 125.
Old December 30th, 2012, 08:45 AM
Alright I'm convinced on the shorter run <100'.
Now how about tensile/breaking strength? I'm looking at $270 for 100' 3/8" @ 17,600lb, $390 same run @ 19,500, or $530 same run @ 23,900. All with the same safety thimble / winch stop.
Of course I'd love to get away at the $270 price point, but is it really worth twice the price to get the higher 23k tensile strength? Or is 17k sufficient?
Old December 30th, 2012, 09:02 AM
Masterful usually have a discount code for expo guys. Check out their posts over there. Personally, I like the higher strength, but 17k should be fine.
Old December 30th, 2012, 09:07 AM
1of40's Avatar
1of40
1of40
Wow $500 does sound steep. My line is rated at 17-18 and I've seen it lower a 110 verticle from a 15 foot ledge (using a snatch block). I hope to never have to do that again but if I do I wouldn't hesitate for too long.
Old December 30th, 2012, 09:45 AM
revtor's Avatar
revtor
Steve Maietta
1969 IIA 88" Bugeye
How strong is your winch? if you have more than a 17k winch I'd go with the $400 or $500 option. Otherwise the 17k will be fine. It's 3k lbs stronger than 3/8 steel cable which was fine back when we had no other options.
Old December 30th, 2012, 09:49 AM
Sporting the Warn M10000, I'm going to go with the 3/8 17k in either 80' or 100' I'm pretty sure.
Old December 30th, 2012, 01:01 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
This. I still don't understand why everyone is obsessed with 30,000# rope to replace the 8-10000# wire cable on their 9000# winch. Sometimes overkill is a good thing. But having line that strong just transfers the weakest link to another area, be it your winch, shackle, or recovery point.
Old December 30th, 2012, 01:22 PM
It shows up on their website as 3/8ths by 125ft. I bought that exact thing from them through the expo discount. I wanted grey in color so I forget which kind I got.
Amsteel is like $300 for 125ft of 3/8ths.
winch
Synthetic winch line - 3/8" x 100' ini88 For Sale - Parts 43 October 20th, 2012 09:45 PM
Line Lock for Winch Line Maine 110 The Vendors Loft 6 February 7th, 2006 06:47 AM
synthetic winch line good or bad ripp2002 Defender Technical Discussions 1 January 18th, 2005 07:28 PM
Dynaflex Synthetic Winch Lines Starting @ $280.00 RedRhinoProducts The Vendors Loft 1 November 4th, 2004 09:07 AM
WARN 8274-50 Winch, THE ULTIMATE!!! RedRhinoProducts For Sale - Parts 0 September 28th, 2004 08:18 AM
