Synthetic rope users ??'s - Defender Source
Old December 1st, 2007, 09:38 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Those of you running Warn Winches, do you recommend 85 Feet or 100 feet of the 3/8 cable. I snapped my steel so it's time replace. Thanks
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old December 1st, 2007, 10:01 PM
WhiteD90's Avatar
WhiteD90
Johnathan Tisdale
93 110, 90 RockRR buggy
Unless you have an 8274, which I dont think you have, you can only get closer to 85'. I've been running Amsteel for about 7 years, at that time 88' was all that was recommended in the 3/8" variety. I may have spooled out 80' once, usually a closer anchor.
Old December 2nd, 2007, 12:23 AM
rmuller
Ryan
1966 S2a 88" | 2006 LR3
Depends on the wheelin' you do.. I have 100ft of 3/8" on my xd9000, but when I need to replace it, I'm going much shorter, perhaps 50ft, and getting an extension line.. easier to manage, and most of the time, i'm only winching 25-50ft anyways..
Ryan
Current:
1966 Series IIa "Olive"
2001 Discovery II
2006 LR3 HSE7
Old December 2nd, 2007, 06:38 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
I think if you have 100 feet of line and are winching 25 feet and only pull one layer of line off the spool you only have about 1/4 - 1/3 the real pulling power of the winch....so....
The shorther line you can use the better. Personally using about 65 feet of 3/8 and a couple of different length extensions. Wouldn't bother me at all to get down to 50 feet.
It's that or the snatch block and double line pulls (not a bad thing especially if you'd like more control of a fast winch)
Matt Browne
Old December 2nd, 2007, 10:16 AM
mdmccallum's Avatar
mdmccallum
'97 Defender 90 SW
This is my approach. I have 100' of 3/8's synthetic line. When you really need the full strength of the winch you need have about 1/2 of the line out that way you are in the full power range of the winch. This can be attained by pulling out more rope and adding a snatch block or with extensions on the shorter ropes. It doesn't really matter. I have the occasional far anchor therefore, I went with the 100' rope.
Old December 3rd, 2007, 01:58 PM
125' of 3/8" on my 8274. Works great, less filling.
Old December 3rd, 2007, 02:00 PM
AggieD90's Avatar
AggieD90
Kevin Collins
'95 AA Yellow & '97 Willow Green
85' on my XD9000. I'd be fine if it were shorter.
Old December 3rd, 2007, 02:24 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
100' on a 9.5ti and i use snatch blocks
Old December 5th, 2007, 01:07 AM
DiscoDino's Avatar
DiscoDino
Nadim Samara
1992 Disco "Dino"
I have 3/8" x 100 on both my M8274-50s, and althought I would like to have less rope and maybe even go thicker...I sometimes have needed all the length (with 6 wraps on the drum)...i think the 3/8 x 100 is a win-win size...
'92 Disco truggy (42"s, ZF, dual cases, ARBs, 30 splined, OMEs, Optimas, Warns, Bead-Locked)
'04 D-90 TD5 ST (33"s, tuned, caged, 1/2 top)
'84 Rangie 2 door classic (32"s, OME, ARB bar & M8000)
'04 Disco II stock
'07BMW G650X Challenge (farkled)
Old December 5th, 2007, 10:39 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
I went with 3/8 x 85'. Thanks for the help everyone.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old February 9th, 2008, 03:10 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
I need some line for my M8274. who has the best product/prices? I was thinking if 3/8 x 100. is this a good choice for this winch on my IIa coil truck?
Legend in My Own Mind.
Old February 9th, 2008, 06:05 PM
Go with 125'. Still lots of room.
Old February 10th, 2008, 01:23 AM
needsaD110's Avatar
needsaD110
Ben
97 D90 #1345
85' on my xd9000 and had the same rope on my old 9.5xp
2002 dodge 2500 CTD-blows some smoke
1997 LR D-90 ST
Synthetic winch rope and roller fairleads? Santiago Defender Technical Discussions 3 August 3rd, 2009 11:17 AM
Synthetic winch rope Santiago Defender Technical Discussions 8 April 29th, 2008 08:56 PM
line loc for synthetic rope, where to get? KevinNY Misc. Chit-Chat 6 January 23rd, 2006 04:46 PM
Which synthetic rope revisited: snuffer Defender Technical Discussions 0 June 14th, 2004 07:59 PM
Which synthetic winch rope is... howellm70 Defender Technical Discussions 17 May 31st, 2004 01:57 PM
