Synthetic oil to dino oil. - Defender Source
Old June 18th, 2011, 12:31 AM
discotdi
Todd Miller
Land Rover
I have been using synthetic oil in my 200 tdi for about a year and it has gotten so expensive I am thinking of going back to Dino oil. Is it ok to do this? Any thoughts?
Old June 18th, 2011, 08:35 AM
kevkon's Avatar
kevkon
kevin
1994 D90 300tdi #730, SIII 88
There are so many misconceptions on the oil issue, especially syn vs dino.
In reality the advantages of synthetic oil in a motor are that it has a better heat transfer ability and it can be produced in a wider range of viscosities.
Other than that, there really is no great difference.
Both Syn oil and dino use the same additives which break down over time and they both get contaminated. That's why oil changes are done.
Use whatever you like, just change your oil and filter on schedule.
Old June 18th, 2011, 03:02 PM
Originally Posted by discotdi View Post
....and it has gotten so expensive I am thinking of going back to Dino oil.....
How often are you changing the oil? The 200TDI manual says 5000 km, which based on oil analysis of my engine is way more often than needed with the oil I use. 10000 km is a nice conservative interval.
------ Follow up post added June 18th, 2011 01:06 PM ------
Originally Posted by kevkon View Post
Use whatever you like....
That is not the complete truth. Synthetics do reduce wear, but the difference is not a deal breaker for the average user and the amount of miles put on an engine.
You must also make sure you are using a suitable oil for the engine and climate. You would not want to use an oil designed for a gasoline engine in your diesel and some grades are not suitable for some temperature conditions.
Old June 18th, 2011, 04:10 PM
kevkon's Avatar
kevkon
kevin
I would suggest that sevice intervals should be based on individual requirements and operating use rather than an arbitrary mileage figure.
Synthetic oil in itself, does not reduce wear ( unless you believe what synthetic oil makers claim). There are additives put in for that purpose. What synthetic oil does do is decrease oil sludge and build up and provide a more controlled viscosity due to a more uniform molecular structure.
That's why I said " use whatever you like" in regard to syn vs min.
Old June 18th, 2011, 04:28 PM
discotdi
Todd Miller
Land Rover
Really the price is not that big a deal, I was just shocked yesterday when I went to buy oil and the Syn. diesel oil was $27 per gallon! maybe it has been that much forever and I just forgot. It is just $20 more, but I don't know if it is worth it or not.
Old June 18th, 2011, 04:37 PM
Oil analysis shows reduced wear metal when using a comparable regular oil to synthetic such as Rotella versus Rotella T. It is not a huge difference, but it is a difference.
Old June 18th, 2011, 04:49 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Haynes Manual says 6000 miles between oil changes. I usually aim for somewhere in the 5 -6000 mile bracket.
Mike Hammond
Old June 18th, 2011, 07:33 PM
The 5000 km, 3000 miles is from the factory workshop manual.
Old June 19th, 2011, 09:18 AM
kevkon's Avatar
kevkon
kevin
Personally, I would go by hours of use on a Defender unless it is not used offroad.
It doesn't hurt to change the oil and filter more often than the mfg recommendations.
V8 Engine Oil - Synthetic vs Semi Synthetic nickt Defender Technical Discussions 68 September 18th, 2016 09:38 AM
300TDI Synthetic or Dino Oil? drv2fst Defender Technical Discussions 4 October 25th, 2010 09:00 PM
Synthetic or Dino, What do you use??? javelinadave Defender Technical Discussions 16 February 8th, 2005 07:33 PM
