Symptoms of a dieing clutch.... - Defender Source
Old May 11th, 2013, 11:30 PM
petminded's Avatar
petminded
David
1995 Defender 90- Yellow- Soft Top
Hello wise Defenderers. What are the symptoms of a dying clutch? And is there a why to tell if its dieing or just very low on MTF?
Old May 12th, 2013, 12:12 AM
bjf's Avatar
bjf
barry f
94 ST #395
Lots of symptoms for dying clutches, failing slave and master cylinders etc but it might be easier of you say what's wrong with your truck and people can tell you what they think it is.
Old May 12th, 2013, 03:55 PM
petminded's Avatar
petminded
David
My daily commute is short- 2 miles. So its hard to say as i dont really drive it much more that that. What it just started to do is not going into 1st...
When this happens Ill put it into 2nd with the clutch engaged and than try 1st. But no luck. Usually letting the clutch out and putting the clutch back in and I can get it to go into 1st.
This is the biggest change ive noticed
Old May 12th, 2013, 04:02 PM
bjf's Avatar
bjf
barry f
94 ST #395
Sounds like the tranny not the clutch.
Old May 12th, 2013, 05:06 PM
Does it go in easy if you snick it into second and then first?
What part of the clutch travel does it disengage?
Old May 12th, 2013, 09:57 PM
Tyler Wirken
Tyler Wirken
1997 Defender 90 LE
When driving it after getting into first how does it shift through the gears? I just recently had to redo my entire clutch due to a broken spring on my clutch disc that was jammed in the pressure plate thus not allowing the clutch to fully disengage. But it effected every gear not just first.
Could be the synchros going bad in the tranny as well. Hopefully not.
Old May 12th, 2013, 10:15 PM
Put your finger in the gear box full to see if its low.
Old May 13th, 2013, 09:13 PM
petminded's Avatar
petminded
David
Im going to get the trany fluid changed tomorrow and report back. I remember reading somewhere that both gear oil or MTF is ok? Am i remembering wrong?
Old May 13th, 2013, 10:13 PM
Redline MTL. NOT gear oil.
Old May 13th, 2013, 11:05 PM
petminded's Avatar
petminded
David
Lol! Yea not grea oil. I meant to say MTF or ATF?
Old May 14th, 2013, 01:46 AM
HenryT's Avatar
HenryT
Henry Townsend
2000 110 CSW Td5
Mine on my 110 is on its way out. Symptoms are slipping when towing my off road caravan. Happens in first and second. Not so noticeable in 3rd and up without load can't really feel the slip. Trying starting you vehicle and pulling away in 3rd. If it stalls then not necessarily the clutch. If it does pull way and the revs rise before getting to speed then it's the clutch.
Old May 26th, 2013, 01:58 PM
petminded's Avatar
petminded
David
Hi all. Im getting around to changing my fluids this wkend and I hit a snag. This is the bolt in the refill plug in my MT. Anyone know what I need to buy to get this out??
Old May 26th, 2013, 02:41 PM
petminded's Avatar
petminded
David
Found the anwser at Harbor Freight!
Old May 26th, 2013, 03:04 PM
2411D90's Avatar
2411D90
Bob Vogler
1995 D90 Fastback ST (Beluga Black)
Torx #55
Bob Vogler
Recovering Economist
Old May 28th, 2013, 08:57 PM
petminded's Avatar
petminded
David
Finished chaining all fluids except the swivels this weekend. My transfer case was empty. I wonder if this was some of my problems before. Time will tell I guess.
The gearbox had ATF fluid in it. I replaced it with Royal Purple MTF as the stores near me didnt have anything else. The magnetic drain plug had its share of metal filings attached. Should I be concerned?
What do you think about the MTF vrs ATF results? With the MTF in my gearbox now I feel more friction in the stick as I shift into gear. Otherwise it deams ok, but the friction has me worried.
And also since my transfercase was empty, should I change the oil again in a month? Or just go the normal routine?
Thanks in advance!
Old May 28th, 2013, 09:29 PM
Thanks in advance!
I would go about fixing the leak in the t case that caused it to be empty.
MTF is a little harder when cold, but once it warms up it is fine and better. Some shavings in the trans is normal.
Old June 7th, 2013, 03:21 AM
petminded's Avatar
petminded
David
Update: I have noticed that my trans shifts smoother now after a few days of use. As my daily commute is short - about 2 miles each way - I don't get much time in the drivers seat. Either way I'm happy that I went with MTF. It's definitely the better choice.
Does anyone know if Lucas makes an additive that is compatible with MTF?
------ Follow up post added June 6th, 2013 11:26 PM ------
I assume the leak is coming from the flat access panel. Is this panel the most common source of leaks? If I open the panel, do I need a gasket or do I use an adhesive/ sealant when closing t back up?
Old June 7th, 2013, 04:43 AM
I think you need to get in your truck and start driving it more. Two mile journeys are tough on vehicles.
Old June 10th, 2013, 08:08 PM
petminded's Avatar
petminded
David
Today I drove it up to LA- about 30 miles.
------ Follow up post added June 10th, 2013 04:10 PM ------
Whats the process on fixing the leak? As is it wnt dry after only 3 years on sitting in the rain.
Old June 10th, 2013, 09:04 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
It's dying... it died ????????????
The fact that you are asking questions and trying - developing a DIY attitude is a good start. You need to buy yourself a workshop manual that explains the work you intend to undertake, examine the job before you take it on and plan your attack. Start with figuring out where oil could leak from, and keep an eye on those points and read up on how to repair the leak. Then find the parts and when you are ready, get out the tools.
Using terms like dying clutch does not describe the problem.
If you want specific help, be prepared to supply specific information in the form of exactly what is happening.
Years ago, a guy I was working with got a call from his wife who said she parked the car and it had died.
My friend replied "let me get the number of the closest undertaker!".
When his wife got upset, he replied with "you said the car died".
He finally got her to accurately describe what was happening.
The vehicle wouldn't start, but was parked at the YMCA within 15 feet of an auto supply.
My friend asked his wife to go into the auto supply and ask for help.
Turned out she had left the lights on and the weak battery had quickly discharged.
She was on her way in less than 30 minutes with a new battery.
I have always remembered my co-workers response to "the car died" with "call an undertaker". Well you said it died...
Hope this helps.
RDavisinVA
Chattering Clutch - Help R. Kurk Defender Technical Discussions 1 June 26th, 2009 05:33 PM
screaming clutch jimmy salmon Defender Technical Discussions 5 November 24th, 2007 12:32 PM
90 v8 clutch problem robheath Defender Technical Discussions 0 August 19th, 2004 06:45 PM
