swivels - Defender Source
Old August 22nd, 2009, 02:24 PM
swivels
when you guys tear them down do you just reshim them or do new bearings? I think its about 15lbs of pull? My Land Cruiser friend has a pretty cool scale from Marlin Crawler for measuring it. Ive also read there are some different seals to use for the wheel bearings, something about the oil from the diff mixing with the swivels/wheel bearings?
Old August 22nd, 2009, 06:52 PM
jetmech's Avatar
jetmech
Dave McHenry
1984 Landrover 90 CSW
I use new shims and it should be 8 - 10 foot pounds of pull.
Old August 22nd, 2009, 08:03 PM
I just pull a couple shims out.
Old August 22nd, 2009, 08:57 PM
I'm doing it right now, but in metric Its 3.6 - 4.5 kg of pull, after you get it moving. I just bought an assortment of shims, then you just play the shim swap games until the tension is right.
Old August 22nd, 2009, 09:00 PM
Only shim the top? The guy with the cruiser says they shim from the top and bottom and there is a special tool to center the swivel?
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
If you're going to all of the trouble to pull it apart I'd rebuild it, not just remove shims.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old August 22nd, 2009, 09:25 PM
http://www.marlincrawler.com/tech/ax...ade-kit-review these are cool. I figure if I can tear it all down do all the seals brakes and wheel bearings and reshim the swivel life is good. Theyve spent plenty of time offroad and still are pretty tight at 75k. I like that marlin crawler kit.
Old August 22nd, 2009, 09:26 PM
Right, just shim the top. No special tool. You could read the Rover manual or you could just let some cruiser guy tell you how it's supposed to be - your choice!
Old August 22nd, 2009, 09:34 PM
How many miles were on yours? How many shims did you take out.
Old August 22nd, 2009, 10:02 PM
150k+ I started fresh because I replaced the balls.
One shot grease swivels thewap Defender Technical Discussions 11 July 21st, 2010 01:31 PM
I must have a 101FC Trigger Misc. Chit-Chat 35 April 3rd, 2006 03:36 AM
Rovertym springs sheki Defender Technical Discussions 50 October 28th, 2005 01:37 PM
110 Military Swivels, balls, CV's, complete outer Buckon37s For Sale - Parts 20 November 3rd, 2004 12:14 PM
swivel balls what to do when pitted and why are 110 swivels so expensive draaronr Defender Technical Discussions 3 August 29th, 2004 07:35 PM
