Swivel pin shims - Page 2 - Defender Source
Old July 12th, 2007, 04:20 PM
Emerson00
Matt J.
None at the moment
So after doing the swivels, seals, track rod, drag link, and panhard rods (all rods and bushings), I have a new-to-this-wonderful-beast wobble above 60 or 65 mph... it progresses from a mild shake into what I'm thinking you guys are calling a death wobble - wheel moves 1-3 inches at the outside until I get back under 60 mph.
I used new pins and new bearings, old races and shims. I'm guessing I need to add a shim... but what size? And which wheel (both?).
Old July 13th, 2007, 07:19 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
sound to me more like you'd need to remove a shim
Matt Browne
Old July 16th, 2007, 09:54 AM
Emerson00
Matt J.
None at the moment
A proud man would STFU about this, but...
The shims are fine, I think. The lug nuts were loose. I mean loose enough that one flew off last night as we got to our destination, 50 miles from home. I recovered it, and the original lug wrench did the job of putting them back to right. The original jack, of course, was dead (timely thread on here!).
After getting them on tight, we drove 5 miles, stopped and re-checked them. The truck perfectly drove smooth up to 70mph.
BTW, she passed the MD emissions test. All that's left is little stuff and getting a welder on that frame.
(and of course, apologies for thread drift)
Old July 17th, 2007, 06:31 PM
junkyddog11
oil soaked filter
95 RRC 300tdi
If you ever decide to come to New England, please let us know so we can stay home while you drive through.....
glad you got it sorted
Matt Browne
Swivel Pin bearings and preload D90user Defender Technical Discussions 7 May 31st, 2015 04:18 PM
Looking for a RH Swivel Pin Housing D110DC Wanted 7 November 1st, 2009 10:42 PM
swivel pin housing - grease or oil or both? cgalpin Defender Technical Discussions 27 March 9th, 2007 09:16 AM
Interesting swivel ball problem dameek Defender Technical Discussions 1 July 24th, 2005 01:18 AM
