Swivel Pin Housing Seal and Bearing Service - Defender Source
Old April 23rd, 2014, 12:53 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I'm getting ready to replace the gaskets, Seals and Bearings on my Swivel Pin Housings. First time doing it so I am reading up on it to make sure I don't break something. The workshop manual has ok info, I find the Haynes Manual to be more helpful as well as this thread on LR4X4. Now to my questions. Should I cut the seals when installing them as advised by Terri Ann and others? Also, any suggestions where I go to get a fish scale to set the correct resistance? Anything else I should watch out for?
Old April 23rd, 2014, 12:57 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
NO - cutting is a field expedient repair allowing seal replacement without removing everything outboard of the swivel.
Fish scale at Bass pro, big-5, walmart, etc..
Have fun and call if you need help.
Old April 23rd, 2014, 01:06 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
I had 1 seal leaking so I did the Terri Ann method and it works perfect. I saw no reason to tear the whole thing down to replace the seal. Good thing you have a '95 as the upper pins & swivels in the '97's I have yes to nail down what the exact part would be since they're hollow for the rough road sensors. Could be the '93 110 swivels & pins could work (they're bigger) but I'm not sure.
Old April 23rd, 2014, 01:07 PM
Don't cut the seal.
Cutting the seal is for when you don't want to disassemble the knuckle and remove the swivel ball from the housing.
Fish scale? I would try a fishing supply.
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Thanks Brian! It's very likely I'll be calling you halfway through it. Nelly mentioned using the old seal to put in the new one, which seal was that? I'm curious about which parts I can expect to give me a hard time.
Old April 23rd, 2014, 01:08 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Fish supply store. Who would have thought! Thanks guys.
service
Swivel Pin bearings and preload D90user Defender Technical Discussions 7 May 31st, 2015 04:18 PM
Swivel pin housing Oil seal Plate tomaco1 Defender Technical Discussions 9 December 25th, 2010 03:04 PM
Looking for a RH Swivel Pin Housing D110DC Wanted 7 November 1st, 2009 10:42 PM
D90 caliper brake pin - cotter pin help Gardrover Defender Technical Discussions 4 May 29th, 2009 02:01 AM
swivel pin housing - grease or oil or both? cgalpin Defender Technical Discussions 27 March 9th, 2007 09:16 AM
