Swivel pin housing Oil seal Plate - Defender Source
Old December 23rd, 2010, 08:39 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
My 110 front axle has 2 plates and a with a gasket(Joint Washer) between them that hold the Oil seal in the back of the swivel pin housing.
My question is do you need all three parts? the 110 manual 1987+ only shows 2 of them, 1 plate and 1 gasket(Joint Washer)
Parts 12 and 13 in on the Diagram
Old December 23rd, 2010, 11:39 AM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
On the earlier 110 swivel housings there is a wider opening at the top for the extended Railko bushing and swive pin.
Because of this bigger opening at the top it is desirable to have two plates in place to hold in the seal because it would be stronger and hold the upper part of the seal in place better and helping to prevent leaks.
Keith
Big, Red and ... aaa Red..
Old December 23rd, 2010, 12:20 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Saved me again,
Thanks Keith
Where goes the gasket go? On one side it was between the plates, and on the other it was against the swivel pin housing?
Old December 24th, 2010, 11:23 AM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
against the swivel housing IIRC.
Keith
Old December 24th, 2010, 09:22 PM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
I forgot to install one of them and have not seen any issues.
Old December 24th, 2010, 09:53 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
I still haven't figured out if it goes:
seal-metal-metal
or
metal-seal-metal
One wheel was one way, the other wheel was the other?
Old December 25th, 2010, 12:53 AM
I see no reference in any manual to two plates. I call BS.
Old December 25th, 2010, 01:59 AM
Nothing wrong with colouring outside the lines a bit..
Old December 25th, 2010, 08:00 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
Me either, that's why the question, but I took 4 early model swivel housings apart, and they all had 2 plates per side.
I guess I should just leave one off.
Old December 25th, 2010, 03:04 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
I like the extra plate to add strength holding in the seal on the ball. From the inside out. plate, plate, gasket.
Early 110 housings did not go full circle, it's more of a keyhole shape, adding the extra plate should help support the seal better at the "open" part of the swivel housing and keep the leaks away longer.
Keith
swivel pin housing - grease or oil or both? cgalpin Defender Technical Discussions 27 March 9th, 2007 09:16 AM
Temp fix for leaky swivel ball seal? solihul Defender Technical Discussions 5 July 2nd, 2005 05:47 PM
