swivel pin housing - grease or oil or both? - Page 2 - Defender Source
Old March 12th, 2005, 06:45 PM
what size wrench do you folks use to remove the plugs on the swivel housings?
Old March 12th, 2005, 07:18 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
Art never cast a stone!
I guess no one read the post anyone do this.
Sent: Thursday, March 23, 2000 9:14 AM
Subject: Re: RE: [D90] Wheel bearing seals
Dave
The advantage of lubricating your wheel bearings with gear oil is more than just a convenience. Gear oil is a better lubricant for this application, wheel bearings will run cooler as a result of less friction (and the gear oil provides some cooling capacity) and hence will last longer. The disadvantage of this arrangement is you have a greater possibility of leaks. Land Rover installed axle case seals in the rear primarily because of warranty issues in the North America market. Here where Rovers are marketed as "up market" vehicles and the minimum price for one is $40,000+, Rover found that these folks don't want drips on their driveways and garages - period!
In Australia where vehicle durability seems to be of a greater concern, removing the rear axle case seals is standard procedure. On the front another thing done is to remove the front axle case seal, the inner swivel housing seal and the outer hub seal so that literally gear oil can flow from one set of wheel bearings to the other passing through both swivel assemblies and the diff on the way. To accomplish this effectively you need to overfill the diff by jacking the vehicle up in the front. Unlike engines and transmissions you don't create any problems overfilling diffs (within reason!). The other critically important thing you need to do when you are eliminating axle case seals is to upgrade inner hub seals. Before Rover eliminated axle case seals they had either single or double lip hub seals. When they went to grease in the wheel bearings they down graded the hub seals because it is very easy to seal in wheel bearing grease - it doesn't go anywhere because it doesn't flow! The big problem with this arrangement is that these down graded seals don't seal some things from coming in such as water! In my opinion whether you eliminate the axle case seals or not you should upgrade the inner hub seals to prevent the ingress of nasties into your wheel bearings.
On a related subject - swivel housing grease vs gear oil, I haven't seen a debate in a while on this list about it. Similar to the axle case seal issue it was introduced as a solution to a warranty problem - leaky swivel seals and American driveways and garages, but it was actually an improvement, swivel housing grease is moly-disulfide and you can't get a much better lubricant for this application. If you don't want to eliminate the axle case seal but want better wheel bearing lubrication, eliminate the inner swivel housing and outer hub seal and run your wheel bearings in moly-disulphide. Again it is extremely important to upgrade the inner hub seal when doing this.
Bill
Great Basin Rovers
The only trouble with this is plasic axle covers will probly leak! What goes out will go in! If you gots those fancy flange thingys you are goood to go!
Old March 7th, 2007, 05:46 PM
how much gear oil should be in the swivels, half a container, enough to where you can see it in there. I added some to mine but I hate to overfill. Are leaky swivels a bad thing? I dont really see how it could be..
http://www.lucasoil.com/products/dis...tid=2&loc=show i wonder how this would work?
Old March 7th, 2007, 09:11 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
are you running wet hubs
Old March 7th, 2007, 09:28 PM
well, I dont think so there isnt anything leaking out of them
it seems like it would work well in swivels
Old March 7th, 2007, 09:37 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
do you have a manual?
Old March 8th, 2007, 08:07 PM
no i dont
Old March 9th, 2007, 09:16 AM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
do yourself a fav get one......
ebay free rave on dweeb
Looking for a RH Swivel Pin Housing D110DC Wanted 7 November 1st, 2009 10:42 PM
Grease or Heavy Duty oil in CV Housing TND90 Defender Technical Discussions 7 June 19th, 2008 04:14 PM
Interesting swivel ball problem dameek Defender Technical Discussions 1 July 24th, 2005 01:18 AM
