Swivel Pin Fun. - Defender Source
Old February 6th, 2010, 12:00 AM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
Swivel Pin Fun.
So, I am trying to assemble the swivels and everything seems fine until I put the top pin into the railko bushing when the whole thing binds up solid, even with all the shims in place. Any clue what I am doing wrong? All the parts came together (except the housing) in a kit from Paddocks of Britpart parts.
------ Follow up post added February 6th, 2010 12:54 AM ------
UPDATE.
OK, when I left the "thrust disc" out of the other one by accident, things seemed to preload fine. I am guessing that this is not ideal. The other possibility is that they need 3-4mm of shims to preload correctly, could this be the case?
Swivel Pin bearings and preload D90user Defender Technical Discussions 7 May 31st, 2015 04:18 PM
Looking for a RH Swivel Pin Housing D110DC Wanted 7 November 1st, 2009 10:42 PM
Swivel pin shims KevinNY Defender Technical Discussions 23 July 17th, 2007 06:31 PM
swivel pin housing - grease or oil or both? cgalpin Defender Technical Discussions 27 March 9th, 2007 09:16 AM
