Swivel Pin bearings and preload - Defender Source
Old October 3rd, 2006, 12:23 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
Hey All,
Going to re do all the seals on my swivel housings soon and I was going to take a good look at the pins/shims/bearings while I was in there. Any pointers on what to look for and/or preload settings. I do not have a guage to pull on the them to get the exact amount of force needed to check preload as stated in the manuall... any other way of doing this... is by feel suicide or good enough?
Also what is the best way to tell if they need changing? Is it nessicary to change the pin and the bearing or is just the bearing OK?
steve
Old October 3rd, 2006, 02:14 PM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
You can use a fish scale (things used to weigh fish from a sporting good store) to check the pre-load. Not pretty, but it works.
In most cases you can just reshim to get the pre-load correct. Only in really nasty cases do you need new pins and bearings.
Email:
Old October 3rd, 2006, 02:22 PM
D90user's Avatar
D90user
steve
Thats a great idea... any specific brand you reccomend
Really though thanks Mike.
Is it OK to double up the shims or do I have to use one of the correct size?
Old October 4th, 2006, 07:55 AM
ECR's Avatar
ECR
It takes combos of shims to get it right, not just one. When you take it apart you'll see a number of shims in most cases.
Back in the day before I boughrt the proper tools I used a fish scale from K-mart. Did the job nicely, just didn't let anyone see me using it.
Email:
Old September 17th, 2011, 01:37 PM
Is it 15lbs of pull with the scale? I cant find it anywhere?
Old September 17th, 2011, 02:14 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Should be 1.15 - 1.46kg after the initial inertia is overcome.
Fish scale is what I've used for 35 years, works fine. All the manuals say is to use a "spring scale" for non-abs swivels.
I'd put a known weight of the correct amount on the scale to see what it actually reads, in case it reads high or low.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old September 17th, 2011, 07:20 PM
after setting the "pull" I couldnt believe how much slop was in the swivels, the bearings and races looked really good. I am sure I will piss off the power steering pump now.
Old May 31st, 2015, 04:18 PM
Tom, I saw you post elsewhere that the spring scale method is only for non-abs setups and to use some tool and a torque wrench for ABS setups. Any harm in using it with an ABS setup, and if not, is the same "1.15 - 1.46kg after the initial inertia is overcome" value still valid?
Originally Posted by pendy
I'm here for the D's
Transfer box input bearing preload reb78 Defender Technical Discussions 10 October 29th, 2008 05:04 PM
wobble mystery D90user Defender Technical Discussions 23 October 3rd, 2007 05:59 AM
Long post regarding CV Joint/Swivel housing.. Emerson00 Defender Technical Discussions 16 June 12th, 2007 09:11 AM
Swivel ball rust - replacement mandatory? Emerson00 Defender Technical Discussions 3 June 6th, 2007 10:58 PM
Pre load of diff bearings. andersoriginal Defender Technical Discussions 9 October 10th, 2003 04:08 PM
