Swivel Pin - Defender Source
Old July 16th, 2014, 11:25 AM
Divesnowboy's Avatar
Divesnowboy
shaun
2007/110/TD4
Swivel Pin
I accidentally removed the upper swivel pin and cannot get it back into the bearing.
Can I reinstall it without disassembling the Swivel Pin Housing!?
D110 2007.
Old July 16th, 2014, 11:31 AM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
D110 2007.
Yes - bearing is likely misaligned. Use a large punch to gently manipulate and align the upper bearing then try again.
Old July 16th, 2014, 11:45 AM
Divesnowboy
shaun
2007/110/TD4
Thanks for the answer.
So the bearing has a recess in the upper portion of the housing?
------ Follow up post added July 16th, 2014 05:46 PM ------
The housing has a lot of play, is this normal?
Old July 16th, 2014, 12:30 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Have you looked here yet?
http://www.landroverweb.com/landrove...rover-manuals/
Rent my
Old July 16th, 2014, 12:34 PM
Divesnowboy
shaun
2007/110/TD4
Yeah I have. I managed to download the 2007 onwards full workshop guide.
Old July 16th, 2014, 02:34 PM
Divesnowboy
shaun
2007/110/TD4
all is good now, reassembled and test driven, all seems ok.
Thanks all.
Old August 1st, 2014, 07:45 AM
Divesnowboy
shaun
2007/110/TD4
Drove through part of Italy from Switzerland, to Cote D'Azure, then north through the French Alps back home. Around 1600km, so the work I did was okay! :-)
Not so much a newbie anymore.
Swivel Pin bearings and preload D90user Defender Technical Discussions 7 May 31st, 2015 04:18 PM
Hella Euro 7 Pin to 4 Pin Trailer Wiring Adapter Wolf Fabrication For Sale - Parts 2 February 28th, 2013 02:57 PM
D90 caliper brake pin - cotter pin help Gardrover Defender Technical Discussions 4 May 29th, 2009 02:01 AM
Swivel pin shims KevinNY Defender Technical Discussions 23 July 17th, 2007 06:31 PM
swivel pin housing - grease or oil or both? cgalpin Defender Technical Discussions 27 March 9th, 2007 09:16 AM
