Swivel identification - Defender Source
Old April 12th, 2010, 03:13 AM
16kpsi's Avatar
16kpsi
Tony Lawson
1986 D110 ex-200tdi to be 6BT
Hi All,
having trouble figuring out what p/n I need to replace my swivels. They are on a 1992 D110. I can't find any axle ID numbers. 24 spline axles. Taper bearings top and bottom. The bottom bearing cap uses smaller bolts if that means anything. Both sides are toast.
There seems to have been a change for the 1997 swivels on the NAS D-90's, not sure if that affects me but I'm not sure which p/n I need.
anybody have some good ones?
and as a bonus - first one to identify what's wrong - ok, egregiously wrong - in the last photos gets $5 paypal. Trying to keep my sense of humor.
thanks
ID:	26546   Click image for larger version
Old April 12th, 2010, 03:38 AM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Nails holding the pads in place????
egregiously - good word
Mike Hammond
Old April 12th, 2010, 07:26 AM
I thought the nails were a problem too, but then I realized that the brake calipers won't provide much stopping force when mounted to the radius arm. I suggest you reinstall the swivel, hub, and disc, and mount the caliper where it belongs.
Old April 12th, 2010, 08:03 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Standard Swivel Ball FRC2644
Oh and nice pad fitting kit..... Home Depot Special..
Legend in My Own Mind.
Old April 12th, 2010, 12:23 PM
16kpsi's Avatar
16kpsi
Tony Lawson
Mike - you win. What's your paypal? Wrong went to egregious because they only used #16 nails, which allows the pads to float radially. #20's would have been acceptable.
Jim - you win my under-the-breath bet that SOMEONE would make a crack about my brakes being on my trailing arms. But it is a surprisingly good fit.
I'm confused about FRC2644. This usually lists as 'chrome...' and the FTC5105 lists as 'Black...". These are definately Black. Not trying to second guess you Randy, just making sure.
Old April 12th, 2010, 12:49 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
That is the # in my parts book for that truck....
Old April 12th, 2010, 01:10 PM
Are there any chrome swivels around any more except for NOS? Everything is teflon coated now. Black is the new chrome.
Old April 12th, 2010, 01:46 PM
16kpsi's Avatar
16kpsi
Tony Lawson
Black is the new chrome.....great. OK, I'll stop using THAT as an identifier.
OK, thanks Randy
Old April 12th, 2010, 02:16 PM
mikeslandrover
Mike Hammond
Way to go. I never win anything.
Mike Hammond
I have two nice swivels off a NAS 110 if you are in need.
Ron
Old April 12th, 2010, 02:54 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
LOL..
I have the teflon ones on my truck. They are very nice...
Old April 12th, 2010, 05:05 PM
16kpsi's Avatar
16kpsi
Tony Lawson
OK, so mine is an oddball, it seems. I found a partial part number on the flat pad by the driver side spring - painted on, so it was blurring while I tried to clear the grease. 44D or 4413 ...which would match an FTC4413 axle p/n for a 1992 with vented from disks and rear disks (which I have both) - it should be a 63L/64L Axle. Additionally, this matches the use of upper and lower bearings.
The Swivel for this axle is supposed to be a FRC7065 not the FTC5051 - which is the superceed number for FRC2644. I've ordered two - Ron, your 110 ones in theory would not work, but thanks, I may be in touch of these don't work. They're not special order, so if they are wrong, I'll eat shipping, but that's it.
Mike - no paypal?
thanks all. I'll follow up with the results when I get there
Old April 12th, 2010, 05:33 PM
mikeslandrover
Mike Hammond
Mike - no paypal?
I have, but I've no idea of the I.D.
Just use it for buying trials bike bits.
Good luck with the re-building.
Mike Hammond
Old April 14th, 2010, 04:12 AM
mikeslandrover
Mike Hammond
Hey I wasn't in it for the $5!!
Mike Hammond
Old April 26th, 2010, 11:54 AM
16kpsi's Avatar
16kpsi
Tony Lawson
a follow up if anyone cares or for anyone in future this might help:
I removed the whole axle and pulled the pinion carrier - the oil coming out was pretty nasty with the swivel leakage, so I wanted to clean it all out. FINALLY found the axle serial number - a 63L - rhd vented disk. The number was on the underside of the long arm, just under the vent tube attachment (under an 1/8" of waxoil).
Got the FRC7065 swivels and as far as I can tell, they are correct...and got new disk pad pins and springs just for fun
thanks all
Old April 26th, 2010, 12:25 PM
mikeslandrover
Mike Hammond
Glad it's all resolved
Mike Hammond
swivel pin housing - grease or oil or both? cgalpin Defender Technical Discussions 27 March 9th, 2007 09:16 AM
Swivel Fluid rover4x4 Defender Technical Discussions 3 October 12th, 2005 03:07 PM
Interesting swivel ball problem dameek Defender Technical Discussions 1 July 24th, 2005 01:18 AM
Temp fix for leaky swivel ball seal? solihul Defender Technical Discussions 5 July 2nd, 2005 05:47 PM
