Swivel Housing/Diff oil Question - Defender Source
Old September 28th, 2006, 11:14 PM
shawnpalmer's Avatar
shawnpalmer
Shawn Palmer
1997 SW-Arles Blue
Last week I drained my diffs and refilled with 80wt90. Today I was under the truck and replaced the drain plugs with magnetic ones, and noticed that the front diff oil was definitely nastier looking than the rear. As I was thinking about this I remembered that I recently filled the swivel housings with fresh grease. I have never messed with inside the swivel housings, so I don't know how things work in there. Is it possible for the swivel grease to mix with the diff oil? Is there a seal that is messed up in there, or is it okay for this to happen?
Old September 28th, 2006, 11:32 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
If it ain't leaking, don't worry about it.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old September 29th, 2006, 12:22 AM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
if it ain't leaking... it's empty
Old September 29th, 2006, 08:21 AM
thewap's Avatar
thewap
Marc
'95 D90 SW#106
if the stub hub seal goes bad, the front diff's oil will mix with the grease, vice/versa. Not a big deal, as long as it doesn't start leaking all at the wheel which will foul your brakes. (not good). Happened to me.
Old September 29th, 2006, 06:11 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
I run no hub seals & the 3511 bearing seal it works great. keep an eye on you rotors if you get a pull in your stering at all you know you have a leak.
Old September 29th, 2006, 10:04 PM
Billakris's Avatar
Billakris
Kris
Alpine White 95 Soft Top
Is there a problem with just adding oil to the swivel balls without draining the grease out of them? I remember hearing a while ago that a combination is actually the best bet, but really I have no idea.
Kris
Old September 29th, 2006, 10:09 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
no prob just thins it
Oil Cooler Line Orientation Question dnewman9 Defender Technical Discussions 3 April 9th, 2011 06:24 PM
swivel pin housing - grease or oil or both? cgalpin Defender Technical Discussions 27 March 9th, 2007 09:16 AM
