Swivel Fluid - Defender Source
Old October 12th, 2005, 02:20 PM
Swivel Fluid
Should I use something heavier than the mobil 1 (75w-90) that I use in the t-case and diffs for the swivel housings? I think it might have the greese but I am determining that in about 5 minutes.
Old October 12th, 2005, 02:51 PM
Well for those that wheel we use 90wt gear oil, it is far easier to change then the grease. But for those pavment pounders fill them with the grease so you don't have to worry about leaks.
Old October 12th, 2005, 03:05 PM
thanks. It does go offroad
Old October 12th, 2005, 03:07 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
I use 85w/140 in mine.
Rob
Rob Dassler
SWR Automotive
505-872-7818 (shop)
« Slap Clunk | ?????? »
Swivel Ball Fluid Check Grover Defender Technical Discussions 20 December 14th, 2012 12:14 PM
Swivel Ball Fluid Change Help Please isleofbones Defender Technical Discussions 2 September 5th, 2009 12:58 PM
Interesting swivel ball problem dameek Defender Technical Discussions 1 July 24th, 2005 01:18 AM
ZF fluid level goes up and down 48vphantom Defender Technical Discussions 4 March 20th, 2005 01:42 PM
