Swivel balls test - Defender Source
Old August 21st, 2017, 11:02 PM
spikemd
Ted
2001 P38, 2006 LR3, 1991 109
Swivel balls test
Guess which swivel ball is defender vs series vs Santana...
Owning a Santana requires a lot of patience and research to figure out which parts are compatible with series trucks and defenders. Technically, they call it a series IV, hence the hodge podge of parts and difficulty in determining what will work. On the other hand, according to Timm Cooper (whom many of you know) the Santanas were actually built more robustly than defenders and is a good platform for building into an overlanding or offroad rig. more to come...
ID:	285921   Click image for larger version
Old August 23rd, 2017, 03:25 AM
Marthijn
Marthijn Holsteijn
Defender v8 1984
Almost everything is rufly the same just little bit different.
I did a brake system on a santana, nothing compatible. ordering from Spain was a longlasting nightmare.
Some things are improved but i would stick to a original land rover if you like to drive one instead of dreaming how it drives.
Old August 23rd, 2017, 08:50 AM
Chris B
72 + D1 drivetrain =?
This thread may help
http://www.defendersource.com/forum/...rts-55005.html
Resurfacing swivel balls jefhuf Smaller Projects 28 September 27th, 2016 04:12 PM
Rovertym Caster Corrected Swivel Balls & LHD knuckles crown14 For Sale - Parts 6 December 5th, 2012 04:39 PM
Different swivel balls? Jake1996d1 Defender Technical Discussions 23 September 12th, 2012 02:43 PM
Replacing bearings, found swivel balls empty Broncoduecer Defender Technical Discussions 30 December 2nd, 2011 01:46 AM
swivel balls what to do when pitted and why are 110 swivels so expensive draaronr Defender Technical Discussions 3 August 29th, 2004 07:35 PM
