Swivel ball/seal leaking - Defender Source
Old September 18th, 2007, 10:16 PM
jaherring's Avatar
jaherring
Jason Herring
94 D90 ST #1253
And here starts the next chapter in my "build a Defender 90 one failed part replacement at a time".
OK, so my swivel joint on the driver's side started making some noise & upon checking it was empty of oil. I refilled it and it's leaking like crazy (hence the empty situation). Nothing like oil on your brake rotors!
I unfortunately noticed some corrosion on the ball itself - near the upper 1/3 of the ball. Do you think I can get away with just replacing the seal or does the ball need replacing?
Old September 18th, 2007, 10:29 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Actually you need to check the swivel pin preload, if too loose they will leak even with new seals. While you are in there consider the sale on the Longtracks CV's and axles.
Equipe Swivel Recovery Points RedRhinoProducts For Sale - Parts 7 March 17th, 2006 06:01 PM
Swivel Fluid rover4x4 Defender Technical Discussions 3 October 12th, 2005 03:07 PM
Interesting swivel ball problem dameek Defender Technical Discussions 1 July 24th, 2005 01:18 AM
Temp fix for leaky swivel ball seal? solihul Defender Technical Discussions 5 July 2nd, 2005 05:47 PM
» Defender Registry
D90
NPT90
Bessie
JimG92
Add your Defender
