Swivel ball replacement or just seals? - Defender Source
Old May 2nd, 2016, 09:06 PM
DMSLongLake's Avatar
DMSLongLake
Dave Sherwood
1994 D90 ST
Ow do I know if I need swivel balls or just seals?
Obviously something needs to be done :-)
DMSLongLake
Current Rovers:
1994 D-90 ST #734
2006 LR3
2016 RRS
Past Rovers:
1997 Disco I
1999 Disco II
1995 D-90 ST #2731
2003 Range Rover HSE
2008 RRS
2013 RRS
Old May 2nd, 2016, 09:18 PM
Contractor's Avatar
Contractor
Will
1969 IIA
As long as they are not rusty and pitted just replace the seals.
Yours look fine, just leaky.
Old May 2nd, 2016, 09:42 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
You might want to check the swivel pin pre-load as well.
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old May 2nd, 2016, 10:09 PM
From what can be seen on the photo, the swivels look great. Plan for a full hub overhaul.
Old May 3rd, 2016, 02:04 AM
Drain, clean the crap out of the seals, refill with the genuine grease, clean your breather. Drain the diff and see if it looks black. Black usually means the inner seal failed. Check to see if the wheel bearings are tight (any play with the wheel off the ground -- shake the tire to see). Same with the swivel pins. My guess is water got in there or the inner seal failed and allowed gear oil into the swivel housing. Often caused by a blocked breather. Any axle leak the first to do is the breather clean. In my experience that fixes half the issues or more. It it were me, the $40 or so for fluids and the hour for the service is a worthwhile first step before doing a hub rebuild. Sometimes the pitting is inside where you can't see it (especially if it has water in it). So you might get it apart and need to buy balls.
If it is a bad seal, you can cheat and cut the seal at the top, fit it, and glue it back together. I would never do that, but I have see it done successfully.
Old May 3rd, 2016, 01:32 PM
Honestly id rather take the swivel off than do this, ive done it once never again.
Old May 3rd, 2016, 04:15 PM
Omero's Avatar
Omero
Omar Alomar
2000 D110 CSW 6.2 LS (was TD5)
+1 on swivel housing overhaul... Do it right and forget it... I've Done mine last week, not that difficult.
Here's a great video playlist on how to do it
Land Rover Front Axle Overhaul Tutorials: https://www.youtube.com/playlist?lis...Fi5wW4YRZn-miP
I'm for the Russian pencil
Old May 3rd, 2016, 11:49 PM
x2...this caused some serious mystery leaks on my truck.
Old May 4th, 2016, 12:50 AM
mgreenspan's Avatar
mgreenspan
Matthew Greenspan
Land Rovers
Replacing Land Rover front swivel ball seals
You little rebel, I like you.
Old May 4th, 2016, 02:04 AM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
I did mine the the Teri-Ann method and is still holding 7 years later.
Another way I've heard of to replace the seal is to undo the bolts that hold the axle end to the main axle and pull the swivel & brake assembly and half shaft out from the diff. Replace the seal & re-install.
Old May 4th, 2016, 06:51 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
That is what I did.
Just disconnect the brake lines, steering, etc., disconnect the swivel at the axle housing and pull the whole thing off and replace the seals.
Be prepared, they are HEAVY....like 3rd member heavy and awkward.
Rent my
Old May 4th, 2016, 12:18 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
That is what I did. Just disconnect the brake lines, steering, etc., disconnect the swivel at the axle housing and pull the whole thing off and replace the seals. Be prepared, they are HEAVY....like 3rd member heavy and awkward. .
I found a floor jack helped with the weight.
Jimmy Buffett
Old May 4th, 2016, 12:56 PM
Except, he should be doing a proper full overhaul of the hub, not just the swivel seal. Hub seal should be changed, bearing checked and adjusted, swivel bearings checked and adjusted. A couple of hours per side and you know everything is in good order for years to come. You also know what to do when you break something on the trail.
Old May 10th, 2016, 05:52 AM
seaswood
Diesel
Swivel seal
[QUOTE=evilfij;735978]Drain, clean the crap out of the seals, refill with the genuine grease, clean your breather. Drain the diff and see if it looks black. Black usually means the inner seal failed.
Assuming you are referring to the axle breather?
Did not think the swivel had one or does it?
Wheel bearing seal inside grease came out onto brake caliper, seal seemed fine.
But replaced regressed bearings also fine.
At same time swivel seal is starting to leak.
So was wondering about breather, evidently.
Old May 10th, 2016, 11:37 AM
DMSLongLake
Dave Sherwood
1994 D90 ST
Thanks for all the input. Decided to go the full overhaul method, including replacing the balls. However, since I barely have time to do my laundry I have sent it to my local independent LR shop to have it done. $$$$$, but should be good for another 21 years...
DMSLongLake
Current Rovers:
1994 D-90 ST #734
2006 LR3
2016 RRS
Past Rovers:
1997 Disco I
1999 Disco II
1995 D-90 ST #2731
2008 RRS
2013 RRS
Old May 19th, 2016, 06:06 PM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
Curious what they charged you for this overhaul?
1994 Defender 90
2006 LR3 SE
1996 Discovery I (sold)
1991 Range Rover Classic (sold)
1995 Range Rover Classic (sold)
2006 LR3 SE (sold)
Old May 19th, 2016, 09:22 PM
DMSLongLake
Dave Sherwood
1994 D90 ST
$1800ish
DMSLongLake
Current Rovers:
1994 D-90 ST #734
2006 LR3
2016 RRS
Past Rovers:
1997 Disco I
1999 Disco II
1995 D-90 ST #2731
2008 RRS
2013 RRS
Old May 19th, 2016, 09:26 PM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
$1800ish
Sounds like a deal. I remember being quoted $2000-3000 for this job on a truck, thought they were crazy.
1994 Defender 90
2006 LR3 SE
2006 LR3 SE (sold)
Old May 19th, 2016, 09:59 PM
Wow at the $$$$ How much would those custom d60 axles cost?
Old May 19th, 2016, 10:55 PM
mgreenspan's Avatar
mgreenspan
Matthew Greenspan
Land Rovers
That is what I did.
Did you put loctite on the bolts when you reattached it? Which type did you use if so?
ac, seals
Rear Wishbone Ball Joint Assembly, Tie Rod End & Drop Arm Ball Joint Rebuild Kit BMGmotors Defender Technical Discussions 18 June 27th, 2011 01:59 PM
Seal at axle tube/swivel ball snuffer Defender Technical Discussions 8 February 7th, 2011 05:06 PM
Interesting swivel ball problem dameek Defender Technical Discussions 1 July 24th, 2005 01:18 AM
Temp fix for leaky swivel ball seal? solihul Defender Technical Discussions 5 July 2nd, 2005 05:47 PM
Swivel Ball Leak... norros Defender Technical Discussions 19 May 5th, 2004 03:50 PM
