Ow do I know if I need swivel balls or just seals?
Obviously something needs to be done
That is what I did.Another way I've heard of to replace the seal is to undo the bolts that hold the axle end to the main axle and pull the swivel & brake assembly and half shaft out from the diff. Replace the seal & re-install.
