Swivel Ball Replacement - Defender Source
Old July 4th, 2016, 08:17 PM
Shearpin
Henry Stinson
'73 Series III SWB '84 110 tdi
I recently did a quick reseal on my front swivels - specifically, the primary seal and inner axle seal. Both lasted about 7 months. There is some minor pitting and obvious swivel pin wear that I assume put an end to the primary seal.
I am not so sure why it consumed the inner axle seal? The breather works. Is it possible to run without this seal and allow the oil to flow from the diff to the hub?
It looks as though early 110's with 7 bolt swivel ball patterns and "skinny" front suspension arms require part #FTC5105. Is it beneficial or possible to convert from the railko bush to the bearing and pins at this time? What is the preferred aftermarket brand of swivel ball? It looks as though BritPart is sold by most venders...
Time to stop looking for a quick fix and do it right...
Thanks again,
Henry
Old July 4th, 2016, 08:31 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Absolutely.
Many here run *wet* hubs.
Get RTC 3511 hub seals.
Rent my
Old July 4th, 2016, 10:37 PM
Shearpin
Henry Stinson
Good to hear... I am running RTC3511, but I did not realize FTC3276 could be eliminated by using them. I find when this seal fails the oil runs from hub to differential with no return flow.
Thanks...
ac
Swivel ball replacement or just seals? DMSLongLake Defender Technical Discussions 34 June 23rd, 2016 10:34 AM
Rear Wishbone Ball Joint Assembly, Tie Rod End & Drop Arm Ball Joint Rebuild Kit BMGmotors Defender Technical Discussions 18 June 27th, 2011 01:59 PM
Swivel ball rust - replacement mandatory? Emerson00 Defender Technical Discussions 3 June 6th, 2007 10:58 PM
Swivel Ball Leak... norros Defender Technical Discussions 19 May 5th, 2004 03:50 PM
