Swivel Ball "leather" boots - Defender Source
Old November 19th, 2015, 01:05 PM
speedpin's Avatar
speedpin
1985 130 Gen IV
My mod 110 has the optional swivel boots guess to keep dirt off the swivel ball surface so that a particle does not destroy a part of the lip or get lodged in the seal lip.
Anyone run them or have a preference based on running with and without over time. I imagine they hold muddy water after hitting a few trails. I think I am going to remove them.
~ Semper Fidelis ~
Old November 19th, 2015, 04:07 PM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
Although I have no experience with these in particular it would really depend on the leather. Some is almost airtight and depending on tanning could be almost water proof. However if the seal broke or you cracked them I think you'd be in for trouble as they'd hold dirt and water in and grind away at the swivel.
Old November 19th, 2015, 04:48 PM
grnrvrs's Avatar
grnrvrs
Paul
88
When I bought my series rig in the mid-90s it had leather gators on it. I was suspicious of the condition of the swivel balls until I opened up the laces to check, but they were is excellent shape at the time. I seem to recall that the laces were to be at the bottom to allow drainage. IF I had a rig with good swivel balls that already had the leather gators, I would leave the gators on but I would not pay squat to put them on a rig. FWIW
1970 SIIA 88, Sold
Old November 19th, 2015, 05:24 PM
I would just replace the swivel balls with the newer style black ones and not worry about it.
Old November 19th, 2015, 06:38 PM
Do swivels wear out? Both of my trucks don't leak a drop from the swivel, I use 90wt.
Old November 19th, 2015, 07:57 PM
chuckc4
chuck b
Registered User
I would run the gators in dusty/dry conditions and pull them after wet muddy conditions.
Half the fun of owning a Land Rover is working on it.
Wait, have I been brainwashed????
Old November 19th, 2015, 08:01 PM
Yes, they can pit quite badly, but you probably won't ever have an issue in NC.
Old November 19th, 2015, 08:28 PM
My range rover has some scratches but neither leak after replacing the seal, the lower swivel pin on the classic leaks like a sieve
Old November 19th, 2015, 08:34 PM
TeriAnn's Avatar
TeriAnn
Teriann Wakeman
1960 Dormobile
The swivel boots were designed primarily for use in the desert to keep sharp sand grains from damaging the lip of the swivel seal.
The inside leather boots should be soaked in oil before installing. They should be installed with the laced opening facing down so water can drain out. if the truck is used in wet or humid environments the boots should be opened up on occasion and any condensation removed off the ball. If you don't do that the moisture will cause the balls to pit and damage them instead of protecting them. Most of the Series folks don't use them anymore because of this.
TeriAnn
Special on Exmoor Trim Black Leather Elite Seat Set and Black Leather Jump Seats SafariHP The Vendors Loft 3 October 25th, 2012 12:27 AM
Rear Wishbone Ball Joint Assembly, Tie Rod End & Drop Arm Ball Joint Rebuild Kit BMGmotors Defender Technical Discussions 18 June 27th, 2011 01:59 PM
Temp fix for leaky swivel ball seal? solihul Defender Technical Discussions 5 July 2nd, 2005 05:47 PM
Swivel Ball Leak... norros Defender Technical Discussions 19 May 5th, 2004 03:50 PM
