Swivel Ball Fluid leak... - Defender Source
Old June 20th, 2014, 02:40 PM
MikeRuby
Mike Ruby
'95 D90 #2523
Is there a smart method to keep this leak from causing any issues until I can make the time to replace all the seals? I figure I can make the time in about a month, and she's not my DD... but I don't want to create a bigger problem if I drive her a few miles in the meantime... Advice from you smart people would be helpful. Thanks.
Old June 20th, 2014, 02:44 PM
ezzzzzzz
Mark Garrenton
You don't mention how much leakage you're experiencing. Three choices really. Either keep it topped with oil, drain and pump full of CV grease or replace the seal now. Hell, most folks are driving around with empty swivels and don't realize it.
Old June 20th, 2014, 02:51 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
If you're not running in water you could go a long time just pumping the new filler grease in the reservoir. X2 on most not knowing...the bigger concern is when nothing is leaking!
I get nervous and check levels when drips are absent. Post a photo of your leak.
Old June 20th, 2014, 02:59 PM
MikeRuby
Mike Ruby
'95 D90 #2523
thanks...
It's not leaking much... she had sat for about a month when the clutch master cyl finally completely gave out, and this morning as I was crawling around under her finishing the slave replacement, I noticed a nice drip line running down the tire. If you guys don't tell me I'm an idiot, I'll simply top her off for a few weeks and do the whole thing in about a month. I'll stay out of the water in the meantime...
Old June 20th, 2014, 03:11 PM
Bill Larson
Bill Larson
Should be fine, I know guys doing the DD thing with worse. You should switch to grease when you can...better lube quality (IMO), not as messy...but some like old school...it's all good!
Old June 20th, 2014, 03:17 PM
MikeRuby
Mike Ruby
'95 D90 #2523
Thanks for the advice
Swivel Ball Fluid Check Grover Defender Technical Discussions 20 December 14th, 2012 12:14 PM
Rear Wishbone Ball Joint Assembly, Tie Rod End & Drop Arm Ball Joint Rebuild Kit BMGmotors Defender Technical Discussions 18 June 27th, 2011 01:59 PM
Swivel Ball Fluid Change Help Please isleofbones Defender Technical Discussions 2 September 5th, 2009 12:58 PM
Temp fix for leaky swivel ball seal? solihul Defender Technical Discussions 5 July 2nd, 2005 05:47 PM
Swivel Ball Leak... norros Defender Technical Discussions 19 May 5th, 2004 03:50 PM
