Swivel Ball Fluid Check - Defender Source
Old December 15th, 2009, 12:39 PM
Grover's Avatar
Grover
Question Swivel Ball Fluid Check
I checked the fluid level in my swivel balls by using a zip tie as a dipstick with markings at 3" and 6.5". I inserted the zip tie via the fill plug up to the 6.5" mark and the lube level is at 3" on each side. Does this sound like I have enough lube in there? BTW, when I bought the truck, I replaced all the fluids, including the swivel balls with one tube of One Shot for each side. What do you guys think? Should I add more, is it possible to overfill?
Cheers...
Old December 15th, 2009, 01:11 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Sounds perfect. Some swivels had a small check level screw (mine do) and thats about wehre it is. I can take a photo if you'd like.
Old December 15th, 2009, 01:12 PM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
great idea, I would like to know also the correct level...for sure mine is leaking out & I have not check in over a year.
also what fluid type/brand etc.. is recommended?
Old December 15th, 2009, 01:53 PM
Grover's Avatar
Grover
Thumbs up
Kevin,
A picture would be great!
FlaD90,
Use LR One-Shot grease (comes in a plastic tube, almost list toothpast), one tube in each swivel ball. This can be bought at the LR Dealership.
Cheers...
Old December 15th, 2009, 04:17 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
I measured the approx. distance between the drain and check plug and it's right about 3". The check plug is the small 1/4" square head just below the steering stop bolt head.
Old December 15th, 2009, 04:21 PM
Yours should have a level plug as Kevin says. I think only a few of the 1997s (if any) had the balls without the level plug.
Old December 15th, 2009, 04:39 PM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
Not sure when the change occured, but my 97 #1008 doesn't have them.
Old December 15th, 2009, 04:43 PM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
I will check my 94 tonight...thanks
Old December 15th, 2009, 05:24 PM
Grover's Avatar
Grover
Thumbs up
Thanks Kevin...I'll check it tonight...
Cheers...
Old December 15th, 2009, 08:37 PM
isleofbones's Avatar
isleofbones
Mike Deery
1984 D-90
I think I've heard some people recommend draining the swivel balls of fluid and replacing with grease to avoid potential problems with leaking out all of the fluid. Does anyone know about this, have any thoughts, recommendations. I have a '84 d-90 and this is the only fluid I have not tackled/replaced since buying my truck... mainly, because I haven't done it before and am uncertain about how straightforward or complicated the task is. Any advice would be appreciated.
Old December 14th, 2012, 08:54 AM
ron's Avatar
ron
Ron
1994 NAS Defender 90
yes you can use the Land Rover grease
Old December 14th, 2012, 09:13 AM
Ron, so you're just making sure that 3 year old threads get updated ?
Old December 14th, 2012, 09:26 AM
The Dro
Dro
1988 Ninety
Easy on the Eggnog.
Old December 14th, 2012, 09:27 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
And put the shot of LR grease in a pot of hot water so it can warm up. So much easier when filling.
Old December 14th, 2012, 09:53 AM
The Dro
Dro
1988 Ninety
I've used gear oil too. I think Jason was the one who told me he did it too.
Old December 14th, 2012, 10:19 AM
down_shift's Avatar
down_shift
Russell
Good, so stop hoarding Jeff's one-shots and sell them to me so they can be used.
Old December 14th, 2012, 10:23 AM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
I still think that grease is not a great idea if you plan to wheel/wade with your truck
Old December 14th, 2012, 10:24 AM
The Dro
Dro
1988 Ninety
You are not going to believe this... When I went to the storage room to get the Christmas decorations. I found a Rover "Spare Parts" box...
Now I have 5 shots and 7 u-joints... I need help.
Old December 14th, 2012, 12:08 PM
Fedex me those shots! I need at least 2 or three.
Old December 14th, 2012, 12:11 PM
The Dro
Dro
1988 Ninety
I need 2 for my truck.
Ross jumped on them. Sorry!
Swivel Fluid rover4x4 Defender Technical Discussions 3 October 12th, 2005 03:07 PM
Interesting swivel ball problem dameek Defender Technical Discussions 1 July 24th, 2005 01:18 AM
Temp fix for leaky swivel ball seal? solihul Defender Technical Discussions 5 July 2nd, 2005 05:47 PM
Swivel Ball Leak... norros Defender Technical Discussions 19 May 5th, 2004 03:50 PM
