Switches...where to put them - Defender Source
Old November 6th, 2008, 10:52 AM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
I have 6 Carling switches that I need to mount in my 110. I had originally planned to mount them in a box affixed to the front of the tuffy console, but have since changed my mind (or at least can't use the orig. box I had planned for this). so now I am trying to decide where to mount them. I am considering putting them right in the seatbox under the driver seat or directly on the front of the tuffy, but the problem with both of those locations is that the switches are vertical and facing away from you, so they will be difficult to read/view the function diagrams. What do you guys think? Any ideas? I can't use an iron goat or anything because it is an NAS 110.
Old November 6th, 2008, 12:15 PM
NashvilleRover's Avatar
NashvilleRover
Dendy Jarrett
2009 LR3- Well Built
I am working on the very same project.
This is what I am coming up with:
http://www.mudstuff.co.uk/Mudpod.html
It mounts where the ash tray goes (and unless you are a smoker ... who needs it!)
It doesn't damage or require any drilling and all wires come in from behind.
I think this is available at Expedition Exchange.
Let me know what you think.
Dendy
Old November 6th, 2008, 12:19 PM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
Wouldn't that block defroster flow?
I know my 90 has a seriously hard time keeping the ice and slush off the center section of the windscreen and that would make it worse, unless you have a heated windscreen or live in CA.
Email:
Old November 6th, 2008, 12:35 PM
NashvilleRover
Dendy Jarrett
I do have the heated windscreen (thank goodness), but I didn't think of that issue. It looks like it would sit between but I would have to get measurements.
Just want something that can accommodate the need without hacking up the truck. There is the empty space where the clock et al resides in a 90 that is empty, but I hate to cut that up.
Dendy
Old November 6th, 2008, 12:48 PM
Are you using the Tuffy for a radio? I put my Espar controls and 12v outlets in the DIN hole. There's no need for a radio anyway.
Old November 6th, 2008, 12:51 PM
ECR's Avatar
ECR
Originally Posted by NashvilleRover
I. There is the empty space where the clock et al resides in a 90 that is empty, but I hate to cut that up.
Dendy
There is not much depth behind there in a NAS 110.
The AC/Heat duct is right behind that, so measure before you cut a hole in there.
Are you nutz??
What do you do to drown out the tire noise?? Listen to the voices in your head?
Email:
Old November 6th, 2008, 03:44 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Yeah, I had planned to mount a light (like Len's) with the seat heater switches and two additional 12v outlets in the area where a 90 has its clock etc. but found out (fortunately before I cut the dash) that there is no room for anything there in a 110.
I'm not sure about that pod, I like the idea, but I'm not sure I want them way up there, plus it is way bigger than just 6 switches, it will leave a lot of extra room unless I put the 12v outlets and seat heater switches up there too, but that is a lot of lights right in your field of vision.
Jim...of course I have a radio! I have often thought that would be a perfect place for them, but I don't have another place to put the radio then, and like Mike said, I've gotta drown out the tire noise with some tunes!
I am not thinking about modifying my headliner to accommodate the switches, has anyone else done this? If so I would love to see some pics!
Old November 6th, 2008, 09:54 PM
shawnpalmer's Avatar
shawnpalmer
Shawn Palmer
1997 SW-Arles Blue
I know it won't help much for a 110, but just for reference for anyone with a 90 here are a couple of shots of my switches.
http://i115.photobucket.com/albums/n...r/100_3019.jpg
http://i115.photobucket.com/albums/n...r/100_3017.jpg
switch
air intake hose?? / source for cheap switches NASD90 Defender Technical Discussions 15 July 6th, 2005 02:40 PM
Who Has put one Slickrock gas tank skids? revor Misc. Chit-Chat 4 May 22nd, 2005 11:39 AM
Where did you put your ECU jcasteel Defender Technical Discussions 6 January 12th, 2005 11:31 AM
arb switches - where to put scoloco Defender Technical Discussions 8 January 10th, 2005 09:25 PM
HELP!! I can't put my tranny in gear... JRowe Defender Technical Discussions 1 October 12th, 2003 12:07 PM
