switch panel for carlington switches. - Defender Source
Old March 6th, 2013, 12:50 AM
Skeena river rover's Avatar
Skeena river rover
jeroen
1997 300 TDI 110
Does any one knows if there is a switch panel for carlington switches for the switches on the left side of the steering wheel. LHD. ( 3 switches).
I do not like the original switches and like to replace them with carlington ones.
Cheers Jeroen
Old March 6th, 2013, 01:29 AM
Landy_Andy's Avatar
Landy_Andy
Andy
If you mean where the hazard switch fits, the aperture is too small for Carlings to fit.
Old March 6th, 2013, 01:31 AM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
Not sure if a Carling switch will fit in there? Might be too tall?
MudUK do a switch panel and there are others out there as well.
http://www.mudstuff.co.uk/products/e...ang-mount.html
HTH
Ian
Ok Andy beat me to it while I was typing and grabbing the link...
Old March 6th, 2013, 11:36 AM
Skeena river rover
jeroen
1997 300 TDI 110
Yes that is what i mend. I have one laying around i can try to fit it in. But i think the original switch frame is wider and narrower. The Mud one is taller, but smaller. I will check today to see if i can make it work.
Thanks for the info!
Old March 6th, 2013, 11:49 AM
The Dro
Dro
1988 Ninety
I might have one... I'll snap pics tonight
Old March 6th, 2013, 12:26 PM
Landy_Andy's Avatar
Landy_Andy
Andy
This is my switch setup for the new dash I'm gonna make....
http://i946.photobucket.com/albums/a...ps8fb1e9b6.jpg
Old March 6th, 2013, 12:42 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Where did you source panels and switches?
Old March 6th, 2013, 01:24 PM
Landy_Andy's Avatar
Landy_Andy
Andy
I got the panels & switch caps (with the legends on them) here : http://www.otrattw.com/index.php
And the switch bodies were from Digikey... only reason did that was OTRATTW didn't have enough in stock at the time.... and they were also a buck or so cheaper as I bought 10 of them, covered the additional shipping.
The hazard switch was from MUD UK..... it's the direct replacement for the LR one, OTRATTW does stock it (I think) but you'll need the correct part # as it's not obvious which one to use.
Old March 6th, 2013, 06:45 PM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
Similar set up to mine from the same places (MudUK and OTRATTW).
Looks like you may run into the same problem as me though Andy. That Hazard switch is designed to work the other way up. When you wire it up you cannot change the orientation of the (single) lamp. The lamp will be at the bottom and shine through the body of the rocker when lit up. It will flash when its activated, but nothing will shine through the lens.
I just live with it as its bright enough to light up the most of the rocker body and in the dash at night it’s obvious in a hurry which is the hazard switch if I need it.
ID:	67535   Click image for larger version
Old March 6th, 2013, 10:17 PM
Skeena river rover
jeroen
1997 300 TDI 110
Hi Andy,
Nice project. I have seen it on rover landers
Yep that is what i want just not sure if it will fit. I do not want to go with a MUD centre dash. Just replace the switches for carlingtons. The original ones are crap
switch
Small Center Dashboard Switch Panel Wolf Fabrication Smaller Projects 10 March 10th, 2009 01:16 PM
SW rear door Switch Panel and switches SafariHP The Vendors Loft 0 May 29th, 2008 10:39 AM
97 Switch panel? Quimbola Wanted 5 November 1st, 2004 08:20 PM
