Switch from ST doors to SW doors - Defender Source
Old August 28th, 2005, 12:46 PM
TAIIISI
Lisa Cresson
I am looking into switch from ST doors to SW doors. On this sight I have read that it is possible but very little information on how to actually do it. Is it as easy as just bolting on SW doors? Also, where should I look to purchasing SW doors? Any input or thoughts will be appreciated. This is for a 97.
Dave
Old August 28th, 2005, 02:17 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
Its as easy as unbolting the old and replacing with the new. Try Rovers Down South for the doors.
Jimmy Buffett
Old August 28th, 2005, 04:16 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
quick before George floats away. I hope he is out of there.
Like Tyler said. Very easy just need the doors and latches. THey bolt right on with the same hinges
Legend in My Own Mind.
Old August 28th, 2005, 11:15 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I swapped my ST doors for SW doors. The hinges are identicle. The locks, latches and strikers are different. The strikers (or whatever they are called) that are mounted on the truck body are different diameter than on the ST doors, so make sure you change these out too. Also, there is a slight difference in what mounts to the bulkhead that keeps the doors open (YES! with SW doors, they can stay open without a bungee!).
Basically, no problem whatsoever. No holes to be drilled, welding or anything...just bolts right up with the correct hardware. Also, with the SW doors, you won't get D90 elbow...
Old August 29th, 2005, 03:02 AM
Mark M
Mark Mathews
'94 Beluga Black ST
What year is your defender? if it is a '95 or '97 I might be interested in buying your old doors. I have a '94. The doors are always trying to amputate my legs. The '95 and '97 soft-tops had a re-designed strap that would actually hold the door open. If you want to get rid of the old bits let me know.
-Mark
Old August 29th, 2005, 12:27 PM
mgrgpg
Mark
1989 D110
rust
when looking for sw doors - the obvious thing is rust...on another thread here I mentioned that the frame was rusting behind the aluminum skin and that the paint is now bubbling due to the oxidation of the aluminum.
door, switch
trade SW doors for ST doors ron For Sale - Parts 13 October 17th, 2008 11:33 AM
Trade: ST doors! TwisteD90 For Sale - Parts 1 July 15th, 2004 07:55 AM
which is worth more ST or SW ron Defender Technical Discussions 3 March 2nd, 2004 09:12 PM
ST doors an SW rover4x4 Defender Technical Discussions 6 October 6th, 2003 02:29 PM
