Swinging NAS Tire Carrier - fitted to an ROW Ninety? - Defender Source
Old August 28th, 2010, 02:38 PM
DNinety's Avatar
DNinety
JP
1984 Ninety 200TDI
Has anybody been through this? I've recently acquired what I believe is a original "swing with" tire carrier from a 95 NAS Defender. Upon initial inspection it appears that my right rear turn signal is inconveniently located right where the carrier hinge is meant to attach. I've been traveling and haven't had the time to really explore this, other than make a quick observation as my garage door was closing as I left for the airport....
Old August 28th, 2010, 11:11 PM
D90DRC
D Cantrell
1997 D90SW
Not sure how to help but if you decide not to use the carrier PM me and ill take it
Still waiting for the Hope and Change to start
Old August 29th, 2010, 08:08 AM
I installed one a ST tire carrier on my SW, a few years ago. It is designed to be installed in the passenger side rear corner, with the backing plate right behind it. So, it will get in the way of the light. You can either sell it and buy a Mantec version or convert the back-end to resemble the NAS trucks. SafariRover (Stephen Peters) has made up a set rear body corner trim to cover the hole for the conversion.
Old August 29th, 2010, 10:28 AM
http://roverhybrids.com/images/DSCN0695.JPG
Old August 29th, 2010, 08:21 PM
DNinety's Avatar
DNinety
JP
1984 Ninety 200TDI
Got home today and no fit w/o mod. All in all an annoying garage day.
Think I have a buyer, but if not, D90DRC can take it for my cost. I stripped it down to metal and plan to por-15 + UV top coat...or I can leave it as-is for you if you want to galvanize it....I'll PM if my guy doesn't need it anymore.
Old August 30th, 2010, 10:19 AM
orionpco
larry burns
1962 series 2a
sorry to hear that does the bumper fit?
p.s. i have the backing plate call me so i can get it to you.
Old August 30th, 2010, 10:40 AM
DNinety's Avatar
DNinety
JP
1984 Ninety 200TDI
Will do - the bumper will fit just fine with a quick mod. I'll PM my home address -
carrier, nas, tire, tire carrier, wing
ST rear tire carrier / tailgate rattling... DiscoDino Defender Technical Discussions 9 December 3rd, 2005 06:50 AM
Safari Gard Tire Carrier Joe P For Sale - Parts 10 November 8th, 2005 06:31 PM
Tire carrier problem - bad threads Antonios Defender Technical Discussions 4 May 7th, 2005 09:15 PM
Rear Tire Carrier Joe P Wanted 1 February 15th, 2005 06:45 PM
