Swing away rear door - Defender Source
Old April 29th, 2016, 07:49 PM
Noyac40's Avatar
Noyac40
1985 D110
I am always impressed with the amount of knowledge on the Source and the willingness to share it so I was wondering if I could tap some of it. I bought a nice 110 5 door and plan to run it with the top off for summer and am wondering if I can use the hinges from the hard top rear door on a swing away gate? also need to buy the door latch mechanism if anyone knows the part number (no lock needed) or has one for sale? Let me know what you have. Will also need the side rails that go from the windshield to the front door pillar if anyone has those or another solution to make sure that the doors close properly without he roof. Thanks!
Old April 29th, 2016, 08:02 PM
Latch, I think I have a NIB one.
Brewie (here) for the gutter kit a pillar to b pillar
Not sure on the hole placement to convert to a NAS style swing away rear half door.. I'll leave that for others- you might need to drill some.
95' D90 - daily driver..
Old April 30th, 2016, 08:20 AM
DPdotCOM's Avatar
DPdotCOM
Dan Pollock
1983 Defender 3 Door
I went soft top with no door gutters, works just fine. Looks a LITTLE goofy perhaps but then again I'm just on a 3 door.
I bought a new pair of the lower hinges for a full door for this mod and then a locking latch which, you're right, isn't really necessary and makes one less large hole to cut in your nice tailgate.
It's a fully figure-it-out-as-you-go custom job but actually quite easy.
One pro tip that it took me awhile to figure out: the latch mechanism is one riveted piece, it does not come apart to be sandwiched on either side of the door. You just have to drill a large enough hole to pass the somewhat bulbous handle through the door.
Happy to take as many pics of my setup as you'd like.
Seafoam Green 1983 110 3 Door - sometimes SW, current ST.
Spent it's working years in France, it's mid-life crisis in The Hamptons, and now its golden years in Washington, D.C.
Old April 30th, 2016, 02:50 PM
Noyac40's Avatar
Noyac40
1985 D110
Thanks Dan, Good call on the hole for the latch handle. I was able to line it up today and it looks like it will work with minor drilling. Once I get a latch I can finish it.
Old April 30th, 2016, 03:07 PM
Here is what I have
Old April 30th, 2016, 03:09 PM
And another
Old May 1st, 2016, 09:27 AM
DPdotCOM's Avatar
DPdotCOM
Dan Pollock
Originally Posted by rlynch356 View Post
Here is what I have
yup, that's what i used.
------ Follow up post added May 1st, 2016 09:28 AM ------
Oh, also, be sure to get the rubber seals you're going to use before trying to align jt all perfectly. That'll affect the fit. You'll definitely want them to at least fill in the gaps cosmetically.
Old May 1st, 2016, 12:45 PM
Noyac40's Avatar
Noyac40
1985 D110
Definitely noticed the difference when I added those seals - lines up much better- Thanks Dan
Robert, you have mail.
door, rear door, wing
Wiring protector swing away door pendy For Sale - Parts 5 May 9th, 2013 02:57 PM
WTB Swing Away Rear Spare Tire Carrier curry Wanted 0 November 8th, 2012 09:01 AM
Mantec rear swing away tire carrier nathanwind Wanted 16 December 13th, 2011 12:50 PM
Building a rear swing away tire carrier jayz Misc. Chit-Chat 25 June 24th, 2011 03:37 PM
Swing away rear tire mount DJG Wanted 0 December 7th, 2005 09:37 AM
