Sway bar rubbing on tie rod - Defender Source
Old February 26th, 2010, 01:40 AM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
I'm putting my truck back together after an axle and diff upgrade. I noticed that when I bolted the front sway bar back up onto the frame, the bar is rubbing against the tie rod. I'm not sure if I did something wrong; it's getting late and I've been working on the truck all evening and I'm groggy.
Here's a shitty iPhone picture:
http://www.flickr.com/photos/defender90/4389395498/
How can I fix this? Will the rubbing go away when I take the truck off jackstands and put the wheels back on?
Before anyone suggests it, I'm not going to remove the sway bars right now.
------ Follow up post added February 26th, 2010 01:03 AM ------
Nevermind. I think I see it now. Need to unbolt the tie rod and move it out of the way, then unbolt the sway bar again and kick the pivots up above the tie rod.
fabbing sway bar mounts J.5 Defender Technical Discussions 1 September 13th, 2007 02:26 PM
Sway Bar Disco Build blkdiscoII Misc. Chit-Chat 1 March 6th, 2005 02:10 PM
Sway Bar Disconnect mdmccallum Defender Technical Discussions 12 December 15th, 2004 08:20 PM
front sway bar mattdh Wanted 3 October 28th, 2003 09:23 PM
SG Rock Gard (tie rod guard) dmarchand For Sale - Parts 8 October 28th, 2003 01:39 PM
