Sway bar mounting pics? - Defender Source
Old December 30th, 2009, 04:13 PM
IPSC_GUY's Avatar
IPSC_GUY
Peter/Lesbo
1983 110, 1985 110, 1993 110...
Could someone with a 110 Preferably an older one with Sway bars mounted snap some pics of how they are mounted?
thanks,
IPSC_GUY
SIERRA II ALPHA
Old December 30th, 2009, 04:23 PM
Sway bars are for girls and jeeps.
If you are going to trail ride it, try and find a sway bar with the quick disconnects, so you can take it off when you are off road.
Old December 30th, 2009, 06:13 PM
IPSC_GUY's Avatar
IPSC_GUY
Peter/Lesbo
Oh yeah Quick disconnects are definitely going to be done, absolutely. Alas the American west is a very big place and to get between wheeling spot I am going to have to spend large amounts of time on road so Sways or Anti roll bars as the Britts are calling them are going to help.
IPSC_GUY
SIERRA II ALPHA
Old December 30th, 2009, 08:16 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Huh,
So am I a Girl, or do a drive a Jeep? Or maybe I never drive offroad.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old December 30th, 2009, 08:20 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
I've got a 4" lift and 33s on my early 110, and I sure wish I had sway bars for the road. I look forward to pics as well. I must be a girl, or my Landy is gay.
Semper Fi!
Old December 30th, 2009, 08:32 PM
you don't need all that lift. 33's ought to fit with liitle to no lift.
Old December 30th, 2009, 09:06 PM
Huh,
Easy there.... Clearly, I was just pushing his buttons. Although, I do not run mine on either of my 90's. But, I am also not running a 110 with a full NAS cage.
You did say your truck was gay...
Old December 30th, 2009, 10:28 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
I don't think my 97 has front brackets for sway bar mounts. The rear does.. Same as a 90.
The front factory sway will rub on your driveshaft if you droop more than 2"
IMPO find a better way if you need one...
Keith
Big, Red and ... aaa Red..
Old December 31st, 2009, 12:24 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
IPSC_GUY
SIERRA II ALPHA
Hey,
PM me or call Pat to talk to Aaron about my (his) swaybar. Believe it or not the sway bar built in the pic above was built using toyota parts. You can get one or two at a very good price. No disconnects and you get the benefits offroad which is where they really kick butt. Only for girls or Jeeps though.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old December 31st, 2009, 07:58 AM
Wolf Fabrication
Sterling Archer
'08 D3
Of course not, but my truck came with the lift, so why take it off.
Semper Fi!
Old December 31st, 2009, 09:06 AM
instability requiring the addition of otherwise unnecessary hardware? complications caused by caster angle, driveshaft angles, etc? All of this while running a stock-ish tire size offering little to no improvement in axle to ground clearance.
Hey...to each their own. but I would get an angle finder and look at where your caster angle is, that may be the real reason you are looking for sway bars. Peter Lesbo too.
Old December 31st, 2009, 09:16 AM
Wolf Fabrication
Sterling Archer
'08 D3
?? Needing sway bars has nothing to do with caster angle.
There is no need to debate the need for sway bars, we have done this before. It's up to the individual. I prefer sway bars on the road.....
Semper Fi!
Old December 31st, 2009, 10:32 AM
I'm not trying to debate the merits of a particular part. I was just answering your question. It's not as much of a stretch as you make it out to be. If you are looking for equipment to help with handling then there is obviously some issue. Caster plays a large role in how a vehicle handles. Do you know where yours is, or care? I hope you do with a 4" lift on and your family inside.
Old December 31st, 2009, 12:33 PM
IPSC_GUY's Avatar
IPSC_GUY
Peter/Lesbo
Hey,
PM me or call Pat to talk to Aaron about my (his) swaybar. Believe it or not the sway bar built in the pic above was built using Toyota parts. You can get one or two at a very good price. No disconnects and you get the benefits offroad which is where they really kick butt. Only for girls or Jeeps though.
I will try and get a hold of you cats this weekend. Pat, I am sure will be sleeping off a swim (literally) in Guinness.
Where would one acquire said angle finder? Or would an alignment shop be able to diagnose what my current caster angle is?
Part of my trouble is the now uneven nature of my vehicle. With the addition of the cage and the different spring rates front to back, I have about 1.5 inches of lift in the rear and just at 3 in the front. That is going to be addressed and springs are on the way. There is however still a significant amount of body roll. The suspension is a system and coming from a background in Porsche track cars and what I know of suspension systems, Sway bars should help. The quick disconnects will also provide for the best of both worlds. give her better road manners and then let he loose in the hills.
IPSC_GUY
SIERRA II ALPHA
Old January 1st, 2010, 12:31 PM
Home Depot has them. I would think an alignment shop should be able to tell though I've never asked. 2" lift should be sufficient to clear 33" tires.
Old January 2nd, 2010, 11:16 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Can you please tell us very specifically how caster angle change from a lift can cause instability that a sway bar would fix? Then can you tell us how a suspension that does not have a castor problem would not benefit from a sway bar?
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old January 2nd, 2010, 03:02 PM
Hey Dave
I never meant to imply either of those things. I do think that incorrect caster can cause twitchiness and oversteer that might be confused with body roll-related symptoms in certain situations. I also think that 3 inch and over lifts should include some type of caster correction and to ignore that is potentially dangerous.
So, just for the record, I am absolutely in favor of anyone who wants to do so, installing a sway bar on any vehicle. I also encourage a check of steering geometry on modified suspensions. Sorry if I came off as being anti-anti-sway bars.
Also...Dave...you are the suspension guru...I bow to your knowledge on the subject!
Cheers
Dave
Old January 3rd, 2010, 01:32 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Hey Dave
Cheers
Dave
Thanks. I misunderstood what you were saying. I see your point. I am a big fan of swaybars, but like most things, they have to be built right, and are usually not. I have come full circle and used to think they were not that important. I was really wrong.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old January 26th, 2010, 04:03 AM
IPSC_GUY's Avatar
IPSC_GUY
Peter/Lesbo
Ok I have found a good fabricator locally, I have a Front Sway-bar and the required Mounting Hardware. Now all I need is a photo of what the Front Sway-bar Mounting Points look like and their approximate locations, Frame and Axle. This guy can make em and weld em on, so could someone with camera take some quick pics and post em up?
Thanks in advance,
IPSC_GUY
SIERRA II ALPHA
mount
Mounting Lights to the Bar michael15 Defender Technical Discussions 3 February 9th, 2006 08:49 PM
Aux Light Mounting Bar mod4b Wanted 9 July 18th, 2005 01:48 PM
Sway Bar Disco Build blkdiscoII Misc. Chit-Chat 1 March 6th, 2005 02:10 PM
Sway Bar Disconnect mdmccallum Defender Technical Discussions 12 December 15th, 2004 08:20 PM
front sway bar mattdh Wanted 3 October 28th, 2003 09:23 PM
