Hello Everyone,
I did some searching here and didn't come up with an answer to my question. I have a pair of complete puma doors I have mounted to the door pillar but I am having an issue trying to figure out the door striker/latch. The stock latch obviously wouldn't work so I was wondering if there is a latch/striker conversion parts I should get?
Thanks Bozman. I did buy these but not seeing a clean install option. I am guessing I will have to drill new mounting locations. Would love to see someone's install so I can emulate.
Yes, drilling new holes is definitely part of the story. I'm taking mine into the shop later this week in part to get said holes drilled - they have a ton of D's sitting around to make a studied observation of where & how the holes go & I can only assume that they're less likely to miss a cut than I am anyway...
When I installed the new style doors on my 84 I made a template from a stock truck with the new style doors and just drilled the holes where they needed to go.
Maybe you find someone with a tub that can make a template for you?
I had some replacement T-Supports which appeared much older than my new style doors. I simply engaged the striker in the door latch and closed the door to where body lined up. I held the plastic and metal spacer to align with the striker, Marked location and drilled new holes. Happy with the results and doors latch and line up.
I did need to modify the nut plate as there was internal interference on my T-Supports with some sort of reinforcement.
Mine was probably a bit easier since I have no seat in the vehicle so it allowed me to crawl around and mark locations. Also no door seals to obstruct view.
Related Threads
Defender Source Forum
1M posts
24K members
Since 2003
