swaping an EFI in a carbed 110 - Defender Source
Old January 16th, 2014, 10:36 AM
Chris Velardi's Avatar
Chris Velardi
Chris Velardi
1975 101FC
Anyone successfully swapped a range rover or disco v8 EFI into a older V8 110 ? what is the best computer to use , what other inputs are needed to make it run right ( o2 sensors , Mass air flow ....? what is the simplest (least complex ) set up to EFI a 4.6 into an 1985 110 ? any and all feed back of successful installs would be appreciated.
Chris "V"
Old January 16th, 2014, 11:16 AM
I did it on a 3.5 90. Used a complete system from a 3.9l RRC. You need to use all of the sensors that come with it. They are all connected to the manifold/intake other than the VSS and O2 sensors. Make sure to add a vehicle speed sensor as it affects the idle control and you will have stalling problems without it in place. Get the O2 sensors as close to the engine as possible after the pipes come together.
I mounted the intake on backwards with the air cleaner against the bulkhead. This allowed the intake to clear everything.
For a 4.6, you would probably want a custom tune. On my install on the 3.5, it is running a bit rich.
Old January 16th, 2014, 11:23 AM
There is one on ECR's website. I would copy that. Basically you fit NAS 110 fuel system (lines, tank, pump, evap you would need to figure out -- use disco/d90/RRC) and a 14CUX system with all sensors. I have not done it, but I have taken apart two NAS 110s, am building a NAS 110, and had a carbed V8 110.
Old January 16th, 2014, 11:33 AM
rovertrader's Avatar
rovertrader
Dale
Chris- interested in the take off manifold/carb if Edlebrock in lieu of stock
NAS 110 Rear Bumper Reefminis Wanted 3 October 2nd, 2006 04:54 PM
1986 Land Rover 110 Soft-Top Tdi Lurker For Sale - Vehicles 3 June 7th, 2006 11:03 AM
Disco 3.9 into 110 Jimbo Defender Technical Discussions 6 August 19th, 2005 03:29 PM
Importing a 110 to the States mfreeman17 Misc. Chit-Chat 18 April 14th, 2005 02:02 PM
D90 withdrawl :( 110 build :) evilfij Defender Technical Discussions 6 October 23rd, 2004 01:04 AM
