SW window clips that hold the glass to the regulator? - Defender Source
Old May 19th, 2010, 07:41 AM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Now that all the real problems are fixed, time to take care of the small stuff.
Anybody have the part number, proper name, or any other info on the two white clips that connect the window glass to the regulator in a SW roll-up window? Mine are both busted on the driver side, and I kinda need to roll the window down occasionally now that summer is almost here.
-Hans
My oil line fix
My 100k stopped odometer fix
Old May 19th, 2010, 09:04 AM
Since I have a 93, my window doesn't use the clips, so I don't exactly what the regulator track looks like that you have. Given that, when I was looking for a new window, RDS told me that all I had to do was bust off those clips to use a later model window in my 110. I'm assuming therefore that you have a track that attaches to the bottom, and the white clips just line it up on the track.
Originally, my glass was actually held on the track by a rubber channel gasket. My glass guy removed the gasket, and in place, used a 3M special glue to glue the glass on the track. If that's the case, do you really need the white clips? Might be worth exploring.
Old May 19th, 2010, 09:33 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
They are "clip, glass holder", STC4787 (Was ALR6219 then AWR7092 and now the STC4787)
2.47 UKP
Old May 19th, 2010, 10:03 AM
Well now I know too. thanks for posting that. that is quite different from a pre-94 style.
Old May 19th, 2010, 10:36 AM
I had to get these clips in order to use the tinted 93 glass with my new-style doors. They just glue on, easy.
clips, glass, window
Defender glass choices-lessons learned Overlander Defender Technical Discussions 1 May 14th, 2010 10:51 PM
Need measurements for SW side window placement dave_lucas Defender Technical Discussions 17 May 30th, 2009 05:14 PM
Help installing rear window glass PCRover Defender Technical Discussions 7 December 25th, 2007 02:44 AM
Replacing sliding glass window vesparover Defender Technical Discussions 1 January 22nd, 2007 08:55 PM
window regulator handle? snuffer Defender Technical Discussions 2 November 21st, 2004 10:22 AM
