SW Top Install Question - Defender Source
Old January 7th, 2008, 09:17 PM
PCRover's Avatar
PCRover
Gary Young
'94 90ST -> SW
Is there supposed to be some kind of metal spacer or such between the side bottoms and the tub where the bolts attach the two? Mine has nothing and it doesn't feel like the top is on very secure as the seal lets it wiggle around. I think I am missing some thing there to make the connection solid.
Update!
I found this picture of what looks like a spacer in the corner. Is this stock and where can I find them if they are?
Gary
Old January 8th, 2008, 01:30 AM
Yeah, there is a set of "pegs" that the top sits on. That being said, I just bolted mine on. I know LenB did the same thing. Its harder to get the top lined up, but it still works fine. It needs to be down pretty tight, that seal will compress dramatically and there should only be a small gap between the top and the tub.
Old January 8th, 2008, 09:22 PM
PCRover's Avatar
PCRover
Gary Young
'94 90ST -> SW
Looks like I will give up the search for these "pegs" and just bolt her down the best I can. Thanks!
Gary
Old January 9th, 2008, 10:34 AM
Gkase's Avatar
Gkase
George Kase
1983 110 200Tdi CSW LHD
Yes, I also just bolted it down on top of the rubber seal...seems pretty solid when you wrench it down snug...
Fiberglass top install question d90_1372 Defender Technical Discussions 7 September 14th, 2009 11:07 PM
top question Jim Defender Technical Discussions 2 March 4th, 2006 09:42 PM
Roversnorth Soft Top Install mathman Defender Technical Discussions 5 October 13th, 2005 05:18 PM
Badger Top Question newfD90 Defender Technical Discussions 2 September 1st, 2004 03:38 PM
Hitch/ pull point install question JKM Defender Technical Discussions 3 May 18th, 2004 08:39 AM
