SW Rear Window Clip - Easy one! - Defender Source
Old March 28th, 2012, 02:11 PM
aaronlam's Avatar
aaronlam
aaron lam
1997 Alpine White D90 SW #2212
Hi all,
So finally recovered my headliner... looks great and only cost $200. PIA to get out and in but worth it... thanks Barry for the help.
While everything was out, I got the windows tinted by the installer broke the head off the little screw that holds the clip/opening latch to the side window (2nd image). It seems like the would just pop off completely now but there seems to be something else holding it. I didn't want to pry and break the window.
Any one have any suggestions? Or know how that piece comes off?
Thanks.
aaron
ID:	49605   Click image for larger version
Old March 28th, 2012, 08:01 PM
careful use of a drill ...
Old March 28th, 2012, 08:45 PM
aaronlam's Avatar
aaronlam
aaron lam
Hmmm... I was hoping the solution would be if I scraped the exterior plastic cap off with a razor... it would reveal another screw from the outside... that would release the clip and I would just need to glue the exterior cap back on.
Anyone done this before? If I use a drill... I know I will crack that window.
I just checked and stuck a piece of paper between the latch and the interior window... that broken screw is no longer holding the plastic latch... the paper passes through but gets stuck higher up.
Old March 28th, 2012, 10:34 PM
i replaced mine when someone broke the side window on my truck ... buy the new parts and you'll see how it fits together.
MTC8271
MUC1704
Old March 29th, 2012, 02:01 PM
aaronlam's Avatar
aaronlam
aaron lam
Update... solved.
Thanks Jason for the parts number... helped me figure this all out. So when you remove the visible screw, the catch SHOULD pop right off revealing another screw underneath that which secures it to the plate on the outside through a rubber spacer. That's how it is attached.
Problem is one of my PO in his infinite wisdom decided to epoxy the rubber spacer to the latch itself... so it wouldn't budge. I ended up soldering (drilling near windows still make me nervous) all the plastic off until I got to a hole that I could unscrewed the second screw. Then took the catch off and and hammered the rubber piece off.
Some images and assembly diagram for future reference. RoversNorth stocks most pieces except the rear plate and the rubber spacer.
MTC8271 - LH Window Catch
MTC8270 - RH Window Catch
MUC1704 - Rear Fixing Plate
MUC1707 - Black Exterior Screw
MUC1706 - Inside Screw
MUC1705 - Rubber Spacer
ID:	49635   Click image for larger version
ID:	49637   Click image for larger version
window
Removing rear sliding window from pickup cab dave_lucas Defender Technical Discussions 2 October 31st, 2009 07:49 PM
Gray Interior SW Rear Window Trim J.5 For Sale - Parts 5 December 31st, 2008 10:02 AM
Rear heated window for a 97 SW 97D90 Wanted 5 November 20th, 2008 10:54 AM
Bestop Rear Window MDS Wanted 2 August 22nd, 2004 12:11 PM
