SW interior panel questions - Defender Source
Old January 22nd, 2007, 01:54 PM
94SW,4.6HSE,93LWB,83 110
Installing interior panels in a station wagon top. I have the panels but not all of the hardware or trim parts. Does anyone have pictures or actual pages from the parts books that they can share so that I can see what I am missing. The primary area of confusion is around the windsheild frame. It appears that the head liner is held up by bolts/washers that screw into the windsheild frame. Is there another part that would cover these unsightly bolts ? Also is the piece that comes up the outside edges of the widsheild frame just inside the doors the same as on a soft top ?
Old January 22nd, 2007, 02:20 PM
mountainviewrover's Avatar
mountainviewrover
MARK LECLAIR
95 Range Rover Classic
the small plastic pieces that go around the frame are held in by 2 blk scews on each side. there is a hole in the metal framing that the it screws into.
the fold down sun shades need to be removed prior to installation. that is what hold up the front part of the head liner. i can't recall anything about the dome light but that may need to be somewhat taken apart and reinstalled. anyway, there are also 4 plastic push-in inserts 2 for each side that hold the head liner on bothe sides above the door tops. all the holes are there and should line up for you.
i don't have pictures but i have taken it all apart and reinstalled it so if you need anymore help i may be able to help. good luck. make sure to wash your hands first that material is a bitch to clean. thanks.
interior
SW rear door questions WI-ROTTIE Defender Technical Discussions 11 October 23rd, 2007 02:38 AM
3-Link Suspension Setup questions chrisvonc Defender Technical Discussions 20 July 18th, 2006 10:37 PM
Dumb questions to ask when looking at a defender... Grouchie@irdumb.co Defender Technical Discussions 2 July 6th, 2005 11:31 AM
'94 POE SW questions tbmcneill Defender Technical Discussions 5 May 9th, 2005 11:09 AM
Questions about '94 POE Art Vigil Misc. Chit-Chat 14 June 21st, 2004 01:49 AM
