SW Interior Door Panel Question - Defender Source
Old May 13th, 2005, 10:50 AM
mgrgpg
Mark
1989 D110
I just swapped out my ST doors for SW doors.
I have a set of interior panels and am not sure how they go on exactly.
It looks like there are small black buttons that are molded into the panel. I have a few black plastic ponted parts that slip over the buttons???....these then go into the white plastic parts on the door???
Is this correct?
If it is then I need more of the black plastic pointed inserts, any idea who may have them?
Mark
Old May 13th, 2005, 10:52 AM
norros's Avatar
norros
Nicholas Orros
1995 NAS D90 SW
Correct.
I got mine at 2 different time... buy a BUNCH... from RDS & RoversNorth.
They're cheap.
N
Old May 13th, 2005, 02:19 PM
mgrgpg
Mark
1989 D110
Thanks - would you know the Part Number?...I do not have my parts list here at work, and would like to order them today.
Mark
Old May 13th, 2005, 04:35 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
How'd the project go for you? I'm interested in the exact opposit switch and was wondering if there would be any qerks to it that would drive me crazy. Any pix?
Clay
Old May 13th, 2005, 10:04 PM
Troys
Troy Smith
1995 D90 SW
Mark;
Any interest in getting rid of your ST doors?
Troy
Old May 16th, 2005, 09:05 AM
mgrgpg
Mark
1989 D110
A few comments so far on the install:
1 - I needed longer bolts for the nader pin assembly
2 - The bar that keeps the door for opening too wide is not located in the same place on the SW doors, I need to make a small braket to make it work
3 - On my ST the speakers are located in the door and the interior panel is built out to accomodate the size, on the panels I have I need to get a spacer ring so the speakers do not hit the window when it is rolled down.
That is it so far, nothing major, pretty straight forward.
Mark
Troy - not sure if I will sell the doors and tops yet.
Old May 16th, 2005, 10:08 AM
You probably have new-type doors - the check strap changed design after 1994. All you probably need to do is get the new check-strap assembly and bolt it right on.
Old July 24th, 2007, 09:58 AM
Does anybody know the part # for the black plastic fasteners that mount to the buttons on the inside of the door panel? I broke some and need a bag full to have on hand.
Old July 24th, 2007, 11:00 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
You can buy the same black plastic fasteners at any auto store.
door, interior
Quick radio question - '97 SW Captain Spalding Defender Technical Discussions 3 July 5th, 2009 01:26 PM
Question for SW Owners mgrgpg Defender Technical Discussions 11 February 26th, 2005 07:37 PM
question for SW owners Chris Cox Defender Technical Discussions 0 December 12th, 2004 02:09 PM
Just a quck question for the SW people rover4x4 Defender Technical Discussions 4 December 23rd, 2003 06:50 PM
