SW inner door steel cracking & repair - Defender Source
Old July 16th, 2014, 02:25 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
My SW is very tight, so tight that when I close the doors, if the windows are all closed, I must pull the door real hard. This has obviously lead to my inner door flexing & completely separating just to the inside edge of the lock button actuator. (see picture) I knew I could weld it, since it's steel, but I realized that without some addition "strengthener" it would again crack just beside the weld. Even the passenger door is cracked in the same place but not thoroughly separated is the driver door is.
I decided on a piece of 1/2" steel angle that I have had & to bolt it in several places along it's length to secure it & strengthen the pull. I will weld up the crack before reassembly too. The door card will has to be slightly modified on the ends to accommodate the angle rod also. It is important to tie the angle to the ends of the door frame, I used press nuts on the ends to secure the angle to the frame.
If when you pull on your door handle & you observe "flex" in the door card panel, more than likely your is cracked or even broken. The door lock guides that screw (2 screws) onto the door itself are probably busted too, as the angle of the locking rod causes their flimsy construction to break (new ones on the way & will be re-enforced with JB Weld before installed).
ID:	98844   Click image for larger version
ac, door, rack
SW Door Inner structural panels Wanted FlaD90 Wanted 1 July 18th, 2011 08:28 AM
WTB Front Seats, Inner Fenders & Stuff James Pierce Wanted 8 December 5th, 2010 08:59 AM
97 D90 SW - Inner rear door panel Kimos Wanted 5 December 2nd, 2004 09:26 AM
Fuel line valve cracking RickM Defender Technical Discussions 2 October 21st, 2004 11:15 PM
Rear door inner panel Kimos Defender Technical Discussions 4 October 15th, 2004 12:57 PM
