SW Door panel disassembly - help needed - Defender Source
Old June 13th, 2009, 07:13 PM
got a new set of doors for the 90 - TD5 take offs from SR - great shape and i am having trouble removing the window crank - there is no putton cap for a screw to unscrew it - idea's
also the lock bezel on the door top will not come off - that seems straight forward (at least in theory)
95' D90 - daily driver..
Old June 13th, 2009, 07:31 PM
Lock bezel just pops up and off - push up from the bottom.
The window crank is a new style, uses a "c" clip - do a search for "window winder clip" or something like that and you'll get lots of pix. There's a tool that makes removal easy, but you can do it with a small slotted screwdriver.
Old June 13th, 2009, 07:33 PM
answered my own question - there is a circl clip on the crank - push out both sides and it comes right off
assembly, door
Back SW door card needed isleofbones Wanted 5 June 15th, 2009 10:00 PM
Everything needed for a SW to ST conversion mrfilson For Sale - Parts 10 February 17th, 2009 12:19 AM
Replacing Alt, H20 pump, fan clutch, and belts - Advice needed arbik Defender Technical Discussions 3 January 7th, 2006 09:11 AM
1994 D-90 Factory Bestop parts needed?? Adam Armendariz Defender Technical Discussions 2 March 30th, 2005 08:25 PM
What Parts Are Needed For A P/U Cab? javelinadave Defender Technical Discussions 6 October 25th, 2003 09:48 AM
