SW 3rd Brake Light - Page 2 - Defender Source
Old July 7th, 2012, 01:42 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Any of you boaters out there have experience with: 3M Marine Black Adhesive Sealant 5200?
Old July 7th, 2012, 02:48 PM
Yudda's Avatar
Yudda
Rob
1997/300tdi/110
If I read it correctly that's for windshield installation. Way overkill and I bet ....messy.
I bought a used take off light and it definitely had black foam tape.
------ Follow up post added July 7th, 2012 09:52 PM ------
I've used lots of 3m 5200 and it's for bonding panels together. I used it to bond my fly casting deck on my flats boat. Worked perfectly but definitely not for this install.
It is great stuff to have around...for example to seal the outer seams on the defender roof....white not the black.
------ Follow up post added July 7th, 2012 09:58 PM ------
If you don't like the regular 3m trim tape this is the commercial version.
http://www.ebay.com/itm/3M-4929-VHB-...item5d342dc8fb
They only sell it in big rolls but this guy on eBay sells 5 pieces of 4" squares for cheap.
It's The VHB variant. very high bond.
That should definitely hold our little light.
Hope it helps.
Old August 29th, 2012, 11:58 PM
AgRover's Avatar
AgRover
Adin
1997 Defender 90 SW Badge #2493
Does the Ron Francis 4" LED brake light work with the Mantec interior window guards? I have them and want to install. Does anyone have pics of this setup?
Old August 30th, 2012, 12:17 AM
AgRover's Avatar
AgRover
Adin
Originally Posted by Manimal View Post
Reviving this old thread. I just got Mantec Interior Window Guards and when test fitting I noticed that the 3rd Brake Light needs to be moved up slightly for everything to fit. I am also considering replacing the heated glass so I would have to remove it anyway.
What is the big difference between the 90 and the 110 3rd Brake Light? How does the 110 Light attach to the glass? It appears that the 90 glass uses double stick tape or glue. It was mentioned here that the 110 light is so much better then the 90. How so? Is it worth upgrading to the 110 lamp assembly?
Did you find a 3rd brake light that is compatible with the Mantec interior window guards? I would really like to go with an LED setup (but not just an LED bulb in the stock light).
Old November 2nd, 2012, 11:27 AM
AgRover's Avatar
AgRover
Adin
LED Third Brake Light
Originally Posted by dmarchand View Post
I recently used a Ron Francis 4" LED rear light for the door. Look nice and is factory similar (not exact of course).
http://www.ronfrancis.com/products.asp?dept=25
Nice light, easy install of course.
Do you have a pic with the LED 3rd brake light installed? I am looking at going the same route. What made you choose the 4" vs the 10" light?
Old November 3rd, 2012, 12:35 AM
Thanks for the Ron Francis link. Bookmarked for later use in my build.
brake, ht
3rd brake light setup Defender13 Defender Technical Discussions 3 March 24th, 2006 06:14 PM
3rd brake light assembly, bolts for spare, 90ST cafemosaic Wanted 0 January 24th, 2006 09:23 PM
Tailgate, Tire Carrier, 3rd Brake light, rear bumper jabber For Sale - Parts 5 December 8th, 2005 02:10 AM
tire carrier, 3rd brake light, and other stuff jabber For Sale - Parts 12 January 20th, 2005 03:06 PM
Tyler.. your 3rd brake light chrisvonc Misc. Chit-Chat 5 June 25th, 2004 03:10 PM
