Suspension swap, what else to do/change ? - Defender Source
Old October 11th, 2011, 04:39 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
I'm going OME soon, factory springs and shocks need a
break, what else should I check, change, modify while
I have suspension in pieces ?
EE lower retainers or complete spring retainers kit ?
LR genuine rubberized shock tower securing ring ?
LR genuine rubberized spring isolator? Where?
RN or TerraFirma spring retainer plate ?
Please chime in.
- Charles Eames
Old October 11th, 2011, 06:31 PM
You wont needs retainers for standard ome suspension. I did the rubber shock tower rings and isolators on top of the rear springs. A good time to do at least frame end bushings in front radius arms and rear links. Ditch the rear sway bar.
Start reading all the "installed lift have vibrations" threads.
Old October 12th, 2011, 11:59 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
I'm doing all the front and rear bushing at this time.
Just finished the radius arms bushing, next is panhard
rod bushings, then I'll do the rear.
Phillip, so you used RBC100111 on top of front springs
and ANR2938 on top of rear springs ?
ID:	42659   Click image for larger version
- Charles Eames
Old October 12th, 2011, 12:12 PM
thats the ones
Suspension Question (swap from my RRC to the 90) AggieD90 Defender Technical Discussions 7 January 15th, 2008 07:29 PM
Front Suspension Buckon37s Misc. Chit-Chat 17 November 27th, 2006 01:02 AM
roof rack swap RiMiD814 For Sale - Parts 2 March 5th, 2006 12:04 AM
Thinkin' about an engine swap! rustydefender Misc. Chit-Chat 11 June 17th, 2005 09:30 AM
